need help with my a12
From Brisbane
i pulled my a12 head off because i have a blown head gasket and im just wondering when i put it back together just wondering how tight to do the head bolts with the torque wrench thanks jarryd
Posted on: 2009/12/31 3:46
Re: need help with my a12
From perth western australia
if i remember rightly it is 44pounds... ill have a look in my manual right now for ya
Posted on: 2009/12/31 3:56
1000 coupe aka kb10
WHERE THE HELL IS ROBOCOP... DOES ANYONE KNOW
sorry dude couldnt find it but i am pretty sure it is 44pounds,,, the wiki should have it in there aswell
Posted on: 2009/12/31 3:58
1000 coupe aka kb10
is that 44 pounds with a hammer popo?
Posted on: 2009/12/31 4:01
It depends on which head bolts you have.
Early A12s have one torque figure, but those with the updated head bolts can/should use the higher torque specification. This will help prevent blown gaskets. The better bolts have "13" on them.
The specs are:
A12 33-36 ft-lb 4.5-5.0 Mkg (to engine # A12-470084)
A12 40-43 ft-lb 5.5-6.0 Mkg (from engine # A12-470085)
Possibly A12s after 1973 might be even higher torque -- anyone have the specs for say a 1978 A12?
Posted on: 2009/12/31 4:02
From Brisbane
thanks mine is an 82 model also should i use a type of gasket glue when i put the head gasket in i have hylomar gasket jointing compound but just unsure its what autobarn recommended
Posted on: 2009/12/31 4:10
i thought ity was always recomended not to use any glue/sealant on a head gasket
Posted on: 2009/12/31 4:13
Yes, it is recommended not to put anything on a A-series head gasket.
By the way, 1982 A12A head bolt torque is 51-54 lbs. I suspect the 1982 A12 will be the same, as it is virtually the same block.
Posted on: 2009/12/31 4:20
From sydney
a mate of mine owns a head shop and recommends using copper coat on every head gasket i use it on every head i do and never had a problem including my s/c a15
just my 2 cents worth
Posted on: 2009/12/31 5:45
