« 1 (2)
Re: looking for ca18det with loom ecu and box?
From brisbane
dato12oo wrote:
how long would a standard H165 diff last behind a stock ca18det?
Judging by your avatar not long.
Posted on: 2010/1/1 1:51
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From mandurah
haha just upgrade to an R31 item and then you will have disks on the back aswell
Posted on: 2010/1/1 7:34
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
Quite a regular
From melbourne
haha whats that ment to mean? and do you have to get them shortend much? expencive?
Posted on: 2010/1/2 6:01
From brisbane
$1500 - $2000 including the purchasing of the diff if you outsource the work and have it done properly. This will depend on what anti tramp set up you want to run, if any, and what centre you decide to go with.
Diff housing and axles need to be shortened, handbrake set up modified, tailshaft modified, diff mounts cut off H165 and welded to R31 diff.
Keep in mind that your choice of centre can greatly affect the price. An LSD is preferable but harder to find and will need a rebuild (rebuilds are quite cheap on cone style centres). Open, locker or mini spool will be cheaper than an LSD.
Posted on: 2010/1/2 6:30
Quite a regular
From melbourne
thanks for that.. guess ill just keep on saving!
Posted on: 2010/1/2 6:55
From brisbane
Your H165 will live behind a CA for awhile provided you are gentle.
Start doing skids like in your old avatar or tracking the car and the diff's life will be short.
Posted on: 2010/1/2 7:38
From SE Melbourne
I don't think you need a conversion kit as such for a stumpy box to fit - you do need a new gearbox crossmember, and on some boxes you need to change a bearing to fit with a CA bellhousing (all in wiki land I belive).
I just made up my own crossmember...time will tell how wise a decision that is...
Posted on: 2010/1/2 11:16
Mildman, Datsunless
Quite a regular
From melbourne
yeah i was told you need like 3mm around the whole diif to the tunnel to pass an engineers?
Posted on: 2010/1/3 10:37
« 1 (2)
