Re: looking for ca18det with loom ecu and box?
From brisbane
dato12oo wrote:
haha whats that ment to mean? and do you have to get them shortend much? expencive?
$1500 - $2000 including the purchasing of the diff if you outsource the work and have it done properly. This will depend on what anti tramp set up you want to run, if any, and what centre you decide to go with.
Diff housing and axles need to be shortened, handbrake set up modified, tailshaft modified, diff mounts cut off H165 and welded to R31 diff.
Keep in mind that your choice of centre can greatly affect the price. An LSD is preferable but harder to find and will need a rebuild (rebuilds are quite cheap on cone style centres). Open, locker or mini spool will be cheaper than an LSD.
Posted on: 2010/1/2 6:30
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Subject Poster Date
     looking for ca18det with loom ecu and box? dato12oo 2009/12/22 9:28
       Re: looking for ca18det with loom ecu and box? lethal_john 2009/12/22 11:35
         Re: looking for ca18det with loom ecu and box? dato12oo 2009/12/22 12:27
           Re: looking for ca18det with loom ecu and box? 1200rallycar 2009/12/23 13:01
             Re: looking for ca18det with loom ecu and box? dato12oo 2009/12/24 10:55
       Re: looking for ca18det with loom ecu and box? Anonymous 2009/12/25 13:04
         Re: looking for ca18det with loom ecu and box? Mildman 2009/12/26 7:45
           Re: looking for ca18det with loom ecu and box? dato12oo 2009/12/26 14:03
             Re: looking for ca18det with loom ecu and box? estyre 2009/12/26 14:05
               Re: looking for ca18det with loom ecu and box? dato12oo 2010/1/1 1:12
                 Re: looking for ca18det with loom ecu and box? matty 2010/1/1 1:51
             Re: looking for ca18det with loom ecu and box? Mildman 2010/1/2 11:16
               Re: looking for ca18det with loom ecu and box? dato12oo 2010/1/3 10:37
       Re: looking for ca18det with loom ecu and box? estyre 2010/1/1 7:34
         Re: looking for ca18det with loom ecu and box? dato12oo 2010/1/2 6:01
           Re: looking for ca18det with loom ecu and box? matty 2010/1/2 6:30
             Re: looking for ca18det with loom ecu and box? dato12oo 2010/1/2 6:55
               Re: looking for ca18det with loom ecu and box? matty 2010/1/2 7:38
