« 1 (2) 3 »
Re: A12 & A14/15 Conrod Differences
And your conversion goal is... to put RB20 pistons in an A14???
Posted on: 2010/1/7 4:13
From Selangor, Malaysia
ddgonzal : yes..i'm planning to do that conversions..
is it still do able with the decked block?
Posted on: 2010/1/7 4:25
dying to learn A series..help me :)
From Melbourne, Oz
what bore do they require?
Posted on: 2010/1/7 4:28
"I hav achieved wood"
RB20 bore: 78.0mm
Posted on: 2010/1/7 4:31
From Melbourne, Oz
well the a12 rods are 11.5mm shorter apparently, so it seems you may need to deck the block more? but that would meen a wors rod/stroke ratio for high RPMs, but good for torque or turbo?
Posted on: 2010/1/7 4:56
I don't know of anyone who's tried this conversion. We can only guess what is required.
Posted on: 2010/1/7 4:58
From Townsville, Qld
78mm piston? sounds like a plan when this A14 needs another rebuild
Posted on: 2010/1/7 6:58
i'm planning to do so..i've read somewhere in this forum (i forgot which thread ..) where they do rebore to 78mm using RB's piston..
i do know that this conversions is not a problem if doing it with the standard A14/15 block and using its conrod..
but if,using a shorter conrod (A12) this mean that i'll lose my CC's instead of gaining it..am i right?and does it seems possible to do so with A12 conrod?
i'm running out of an idea..
Posted on: 2010/1/7 7:11
From Melbourne, Oz
rod length has nothing to do with CC's its the crank(stoke) and bore that decide this.
Posted on: 2010/1/7 7:28
If there's no problem when using the A14 conrod, and you have an A14 block and crank...why do you want to use A12 rods???
Posted on: 2010/1/7 7:41
« 1 (2) 3 »
