anybody got weights of standard A15 conrods?
From bathurst nsw
hi guys, just after the weights of a standard A15 conrod i have only got balanced ones to measure, and the weight of a ca16de conrod.
cheers kurt
Posted on: 2010/1/7 22:55
My car gets me from A to B...Just faster ;)
Re: anybody got weights of standard A15 conrods?
kurt the ca18det rods are supposedly almost the same.
Measurements are a bees prick in difference.
The Spools rods are 5 or so gsm heavier than the stock
ca18det rods so should give you a good base.
Posted on: 2010/1/8 0:20
From Christchurch NZ
Ca16 rods are lighter than ca18 rods. Although at a glance you woulnt pick it. I have the numbers in a notebook somewhere. Which reminds me I haven't seen it for a while............
If it doesn't turn up soon ish, I'll reweigh some for you.
Posted on: 2010/1/8 2:41
Forced Induction!
From Perth
The spool CA18 rods are 560 grams each with rod bolts (according to them)
but you probably knew that already
Posted on: 2010/1/8 4:44
5gm difference in conrods can be the difference between winning a race or losing it.
If the engine has to accelerate 5 extra grams 30,000 times per minute that a significant amount of HP spent internally instead of going out the flywheel.
For a street car it matters not much.
Posted on: 2010/1/8 6:43
I think the best bit about the CA16 rods is that they use a 9mm rod bolt. So they are mad stronger right from the get go.
Posted on: 2010/1/8 9:00
Forced Induction!
From Melbourne, Oz
AHAHA no one answerd hes question?
Posted on: 2010/1/8 10:08
"I hav achieved wood"
I can't find my damn note book. I suspect that mrs A14force has "tidied" it away somewhere. I like to leave things where I put them, but she is like nah, I'm gonna hide your stuff.
Women, you can't live with them, and you can't shoot them!
Posted on: 2010/1/8 11:41
Forced Induction!
You can shoot them depends with what ;)
But seriously I didnt know about the ca rods having thicker rod bolts.
I was actually considering using worked a14 rods with ARP rod bolts on a CA
thinking they are better than the ca18de/t rods by being a tad lighter round
the big end but thicker on the shaft.
Theres a picture somewhere comparing the A series rod with a ca rod.
Posted on: 2010/1/8 13:59
From Portland OR. USA
I'll weigh my A15 rods with ARP bolts when I get home this afternoon and post results...
Update
The weights of the 4 stock A15 rods with ARP rod bolts and nuts installed, no bearings is-
514.32g
514.04g
514.00g
511.81g
Posted on: 2010/1/8 16:29
Edited by Gary_P on 2010/1/8 22:46:17
