« 1 2 3 (4)
#31 Re: CA18DET into 1200 general questions
perthute Posted on: 2010/1/8 5:03
depend's on the engineer ;)
bailz it using all maddat gear btw :)
#32 Re: CA18DET into 1200 general questions
bailz Posted on: 2010/1/8 5:25
it says in legislation that it must have atleast 10mm clearance at all points of the engine at full load.... read the regs mate, dont believe everything u hear
#33 Re: CA18DET into 1200 general questions
Mildman Posted on: 2010/1/8 6:44
You can drop around and check out mine if you like Mike, I'm using a 'ca18det_man' crossmember - with 120Y sway bar....it's millimeters of the firewall.
Mine's infront of the maddat one.
« 1 2 3 (4)
