Re: A-series high RPM water pump mods.
From South Africa
My fans never run more than 50% duty, and its been stupid hot here recently, zero problems
I wouldnt touch those DC electric pumps, seen two fail already for no reason costing the owner a motor each time.
As with everything datsun, keep it simple (my system is stock besides radiator and fans) and 95% of the time it will work just fine for even the most demanding situations
Posted on: 2010/1/13 17:45
'75 1200 B110 - 154hp Race prep A14
'97 Silvia - 600hp SR20 time attack
'07 Hilux - Tow car
Subject Poster Date
     A-series high RPM water pump mods. Rezlo 2009/3/20 9:19
       Re: A-series high RPM water pump mods. dat141 2009/3/20 9:44
         Re: A-series high RPM water pump mods. Rezlo 2009/3/20 9:53
           Re: A-series high RPM water pump mods. dat141 2009/3/20 10:18
             Re: A-series high RPM water pump mods. Rezlo 2009/3/20 10:57
               Re: A-series high RPM water pump mods. Rallytwit 2009/3/21 1:04
                 Re: A-series high RPM water pump mods. ddgonzal 2009/3/21 4:59
                   Re: A-series high RPM water pump mods. Rezlo 2009/3/21 7:21
                     Re: A-series high RPM water pump mods. jmac 2009/3/22 5:02
                       Re: A-series high RPM water pump mods. Rezlo 2009/3/22 5:21
             Re: A-series high RPM water pump mods. racetech 2010/1/12 13:07
               Re: A-series high RPM water pump mods. ROConnor 2010/1/12 13:21
               Re: A-series high RPM water pump mods. racetech 2010/1/12 13:49
                 Re: A-series high RPM water pump mods. Gary_P 2010/1/12 16:55
                   Re: A-series high RPM water pump mods. D 2010/1/12 23:29
                     Re: A-series high RPM water pump mods. ddgonzal 2010/1/12 23:47
                       Re: A-series high RPM water pump mods. ROConnor 2010/1/13 1:45
                         Re: A-series high RPM water pump mods. ddgonzal 2010/1/13 2:26
                           Re: A-series high RPM water pump mods. Dundee1000 2010/1/13 2:55
                             Re: A-series high RPM water pump mods. ddgonzal 2010/1/13 5:32
                               Re: A-series high RPM water pump mods. WhiteSedan 2010/1/13 5:49
                           Re: A-series high RPM water pump mods. D 2010/1/13 2:55
       Re: A-series high RPM water pump mods. Dundee1000 2010/1/12 13:42
       Re: A-series high RPM water pump mods. 1200GXman 2010/1/13 6:46
       Re: A-series high RPM water pump mods. racetech 2010/1/13 6:50
         Re: A-series high RPM water pump mods. racetech 2010/1/13 6:58
           Re: A-series high RPM water pump mods. 1200GXman 2010/1/13 7:07
             Re: A-series high RPM water pump mods. ddgonzal 2010/1/13 7:26
           Re: A-series high RPM water pump mods. racetech 2010/1/13 7:36
       Re: A-series high RPM water pump mods. Rezlo 2010/1/13 8:35
       Re: A-series high RPM water pump mods. sikyne 2010/1/13 8:38
       Re: A-series high RPM water pump mods. racetech 2010/1/13 11:27
         Re: A-series high RPM water pump mods. Gary_P 2010/1/13 16:26
       Re: A-series high RPM water pump mods. Rezlo 2010/1/13 17:45
       Re: A-series high RPM water pump mods. sikyne 2010/1/13 22:14
       Re: A-series high RPM water pump mods. Rezlo 2010/1/13 22:56
       Re: A-series high RPM water pump mods. sikyne 2010/1/14 2:57
         Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 6:01
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 7:06
         Re: A-series high RPM water pump mods. ROConnor 2010/1/14 7:16
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 7:26
         Re: A-series high RPM water pump mods. ROConnor 2010/1/14 7:31
           Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 7:35
       Re: A-series high RPM water pump mods. racetech 2010/1/14 8:15
         Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 8:22
         Re: A-series high RPM water pump mods. racetech 2010/1/14 9:10
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 8:19
         Re: A-series high RPM water pump mods. Rezlo 2010/1/14 8:29
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 9:17
       Re: A-series high RPM water pump mods. superbin 2010/1/14 9:23
       Re: A-series high RPM water pump mods. sikyne 2010/1/14 22:33
         Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 23:47
       Re: A-series high RPM water pump mods. WhiteSedan 2010/1/18 5:45
         Re: A-series high RPM water pump mods. WhiteSedan 2010/1/19 4:52
       Re: A-series high RPM water pump mods. Rezlo 2010/1/18 8:01
       Re: A-series high RPM water pump mods. sikyne 2010/1/18 8:25
         Re: A-series high RPM water pump mods. Fandatstick 2010/1/18 10:06
       Re: A-series high RPM water pump mods. Rezlo 2010/1/18 10:55
       Re: A-series high RPM water pump mods. TJ-Flames 2010/1/18 12:34
       Re: A-series high RPM water pump mods. Rezlo 2010/1/18 19:35
       Re: A-series high RPM water pump mods. sikyne 2010/1/18 22:41
       Re: A-series high RPM water pump mods. superbin 2010/1/19 6:25
       Re: A-series high RPM water pump mods. TJ-Flames 2010/1/20 14:20
       Re: A-series high RPM water pump mods. ddgonzal 2010/1/20 16:17
