Re: A-series high RPM water pump mods.
From NZ
Sikyne's on the money.
Many don't realise this is an important part of how the cooling system works. Block pressure created between the pump and thermostat (or restricter) is what greatly assists the coolant picking up heat (then taking it to the radiator to be dissipated).
This is why you should never run an engine with no thermostat - the water temp reading may come down but that's simply because its not collecting heat from the engine.
Posted on: 2010/1/18 10:06
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Subject Poster Date
     A-series high RPM water pump mods. Rezlo 2009/3/20 9:19
       Re: A-series high RPM water pump mods. dat141 2009/3/20 9:44
         Re: A-series high RPM water pump mods. Rezlo 2009/3/20 9:53
           Re: A-series high RPM water pump mods. dat141 2009/3/20 10:18
             Re: A-series high RPM water pump mods. Rezlo 2009/3/20 10:57
               Re: A-series high RPM water pump mods. Rallytwit 2009/3/21 1:04
                 Re: A-series high RPM water pump mods. ddgonzal 2009/3/21 4:59
                   Re: A-series high RPM water pump mods. Rezlo 2009/3/21 7:21
                     Re: A-series high RPM water pump mods. jmac 2009/3/22 5:02
                       Re: A-series high RPM water pump mods. Rezlo 2009/3/22 5:21
             Re: A-series high RPM water pump mods. racetech 2010/1/12 13:07
               Re: A-series high RPM water pump mods. ROConnor 2010/1/12 13:21
               Re: A-series high RPM water pump mods. racetech 2010/1/12 13:49
                 Re: A-series high RPM water pump mods. Gary_P 2010/1/12 16:55
                   Re: A-series high RPM water pump mods. D 2010/1/12 23:29
                     Re: A-series high RPM water pump mods. ddgonzal 2010/1/12 23:47
                       Re: A-series high RPM water pump mods. ROConnor 2010/1/13 1:45
                         Re: A-series high RPM water pump mods. ddgonzal 2010/1/13 2:26
                           Re: A-series high RPM water pump mods. Dundee1000 2010/1/13 2:55
                             Re: A-series high RPM water pump mods. ddgonzal 2010/1/13 5:32
                               Re: A-series high RPM water pump mods. WhiteSedan 2010/1/13 5:49
                           Re: A-series high RPM water pump mods. D 2010/1/13 2:55
       Re: A-series high RPM water pump mods. Dundee1000 2010/1/12 13:42
       Re: A-series high RPM water pump mods. 1200GXman 2010/1/13 6:46
       Re: A-series high RPM water pump mods. racetech 2010/1/13 6:50
         Re: A-series high RPM water pump mods. racetech 2010/1/13 6:58
           Re: A-series high RPM water pump mods. 1200GXman 2010/1/13 7:07
             Re: A-series high RPM water pump mods. ddgonzal 2010/1/13 7:26
           Re: A-series high RPM water pump mods. racetech 2010/1/13 7:36
       Re: A-series high RPM water pump mods. Rezlo 2010/1/13 8:35
       Re: A-series high RPM water pump mods. sikyne 2010/1/13 8:38
       Re: A-series high RPM water pump mods. racetech 2010/1/13 11:27
         Re: A-series high RPM water pump mods. Gary_P 2010/1/13 16:26
       Re: A-series high RPM water pump mods. Rezlo 2010/1/13 17:45
       Re: A-series high RPM water pump mods. sikyne 2010/1/13 22:14
       Re: A-series high RPM water pump mods. Rezlo 2010/1/13 22:56
       Re: A-series high RPM water pump mods. sikyne 2010/1/14 2:57
         Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 6:01
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 7:06
         Re: A-series high RPM water pump mods. ROConnor 2010/1/14 7:16
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 7:26
         Re: A-series high RPM water pump mods. ROConnor 2010/1/14 7:31
           Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 7:35
       Re: A-series high RPM water pump mods. racetech 2010/1/14 8:15
         Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 8:22
         Re: A-series high RPM water pump mods. racetech 2010/1/14 9:10
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 8:19
         Re: A-series high RPM water pump mods. Rezlo 2010/1/14 8:29
       Re: A-series high RPM water pump mods. Rezlo 2010/1/14 9:17
       Re: A-series high RPM water pump mods. superbin 2010/1/14 9:23
       Re: A-series high RPM water pump mods. sikyne 2010/1/14 22:33
         Re: A-series high RPM water pump mods. ddgonzal 2010/1/14 23:47
       Re: A-series high RPM water pump mods. WhiteSedan 2010/1/18 5:45
         Re: A-series high RPM water pump mods. WhiteSedan 2010/1/19 4:52
       Re: A-series high RPM water pump mods. Rezlo 2010/1/18 8:01
       Re: A-series high RPM water pump mods. sikyne 2010/1/18 8:25
         Re: A-series high RPM water pump mods. Fandatstick 2010/1/18 10:06
       Re: A-series high RPM water pump mods. Rezlo 2010/1/18 10:55
       Re: A-series high RPM water pump mods. TJ-Flames 2010/1/18 12:34
       Re: A-series high RPM water pump mods. Rezlo 2010/1/18 19:35
       Re: A-series high RPM water pump mods. sikyne 2010/1/18 22:41
       Re: A-series high RPM water pump mods. superbin 2010/1/19 6:25
       Re: A-series high RPM water pump mods. TJ-Flames 2010/1/20 14:20
       Re: A-series high RPM water pump mods. ddgonzal 2010/1/20 16:17
