Re: GX Compatible Extractors/Exhaust
From NZ
Here in NZ we have (had?) two styles of 4-1 extractors available.
1. "twin carb" - centre two pipes (ie 2&3) go over the two outers (1&4). To suit twin sidedrafts (Webers/Delortos etc)
2. "Single carb" - centre two pipes go under the outers. Suit std single carb manifold.
I've used both. Same pipe diametre. Don't think the single carb style would flow quite as well due to them needing to 'tuck' down a little tighter where they exit the head. Having said that I'd say they run well with GX set-up.
Posted on: 2010/1/20 10:27
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Subject Poster Date
     GX Compatible Extractors/Exhaust thedevilshands 2010/1/20 5:33
       Re: GX Compatible Extractors/Exhaust Bluemax 2010/1/20 6:08
       Re: GX Compatible Extractors/Exhaust thedevilshands 2010/1/20 6:32
         Re: GX Compatible Extractors/Exhaust Bluemax 2010/1/20 6:33
       Re: GX Compatible Extractors/Exhaust Anonymous 2010/1/20 6:34
       Re: GX Compatible Extractors/Exhaust thedevilshands 2010/1/20 6:38
         Re: GX Compatible Extractors/Exhaust ddgonzal 2010/1/20 8:30
       Re: GX Compatible Extractors/Exhaust levey 2010/1/20 8:35
         Re: GX Compatible Extractors/Exhaust ddgonzal 2010/1/20 8:46
           Re: GX Compatible Extractors/Exhaust 1200rallycar 2010/1/20 10:00
             Re: GX Compatible Extractors/Exhaust thedevilshands 2010/1/20 10:05
       Re: GX Compatible Extractors/Exhaust levey 2010/1/20 10:16
       Re: GX Compatible Extractors/Exhaust Fandatstick 2010/1/20 10:27
