Drain plug location on a12
I'm trying to identify the cooling system drain plug on my a12. I see two likely bolts in the left side of the block adjacent to the centre welch plug.
One is directly below the welch plug protruding orthogonally from the block. The other is below and behind the welch plug and protruding at an angle.
Which one is it?
Posted on: 2010/1/25 1:53
Re: Drain plug location on a12
It is just below the center welch plug on the left (manifold side) of the engine block. This appears about halfway down the side of the block:
It is only halfway from the top because below that is the upper half of the crankcase. The water passages only go half-down the block.
Posted on: 2010/1/25 3:27
That photo above is the late-style engine. So a 1974 A12 will have it there.
The early A12 engine (1970-1974) has it in roughly the same position, but exactly under the center welch plug.
Posted on: 2010/1/25 3:36
Thanks DD. I have a late model a12 and it appears I have both bolts! One directly underneath and one behind.
jpg  IMGP3105_s.jpg (54.86 KB)
7711_4b5d1a8e267b8.jpg 800X532 px
Posted on: 2010/1/25 4:02
Which block casting number is that?
H79 or H50 ???
Posted on: 2010/1/25 5:21
Not sure where to check the casting number, but it says M22 where it says M72 in your picture of the late model engine.
Posted on: 2010/1/25 9:34
Yes, that is the block casting number.
Posted on: 2010/1/25 19:22
M22: A12 block casting from 1974-1978 B210
Posted on: 2010/1/25 21:12
Orthogonally? Well I live & learn. I had to look it up but that's another word that I can add to my vocabulary.
Link 1
Link 2
Link 3
Orthogonal entertainment
Oops, edited to correct blatant spelling error.
Posted on: 2010/1/26 1:35
Edited by Dodgeman on 2010/1/26 7:24:19
Love your Datsun.
Treat it well.
One looks to be protruding hexagonally, but the other looks to be protruding circularly. Could be just the photo?
Posted on: 2010/1/26 5:29
