What would be the diff in Water and Oil Temparature
From Sri Lanka
Hi guys
Just wanted to know what would be the Temperature difference in Water and Oil in Datsun1200,Ex if oil is 80 C the Water temp ? compartively
Thanks
Regards
sumith
Posted on: 2010/1/25 5:34
Re: What would be the diff in Water and Oil Temparature
usually more than the water temp
Posted on: 2010/1/25 5:56
From South Africa, Bloemfontein
On the VW engines (I am registered on a VW club site as well) the VW engines run about 20 to 30C higher on the oil temp compared to the water. This however depend on how the car is driven and how hot it is outside.
Posted on: 2010/1/25 6:03
1977 Datsun 1200GX
Yes, with most automotive engines, the oil temp will be 20 degrees F hotter than the water temp.
You don't want the oil to get hotter than 200F degrees.
Posted on: 2010/1/25 6:04
