electronic dizzy install
From Melbourne, Australia
found a dizzy last night... going to install it tonight
had completely forgotten buying a datrats bluey elec dizzy off another member about a year ago
there is two wires from the dizzy, where do i need to wire them to?
do i still need to plug the original datsun 1200 dizzy wire to anything?
might have to go to repco for a coil though, i guess i just ask for one for a series three bluey?
should be pretty straight forward but if someone can quickly tell me it will save some time
cheers,
michael
Posted on: 2008/10/23 8:31
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: electronic dizzy install
From Melbourne, Oz
Wire's go to the pint on the dizzy (blue=-) (red=+) remove ballest resistor (white block) and get a good electronic ignition coil
i.e. Bosch GT40r or just a GT40 (no "R") one is for electronic and one is for point's not sure witch but they can tell you.
Good luck..
Connor.
Posted on: 2008/10/23 9:35
"I hav achieved wood"
The Series 3 Bluebird probably did have the High Energy ignition but if you have a converted L series Bosch Electronic distributor, then it came from a Series 2 car & these were the last to use the L series engines in Australia & the only L series engines to use the High Energy electronic ignition here.
Surely you can find a coil in a wreckers.
The series 3 car used the CA20 engine.
Posted on: 2008/10/23 9:43
Love your Datsun.
Treat it well.
From Melbourne vic
pink wire to + side of coil Green to -
throw the balist resistor in the bin and
tape up the little black wires. I think its
gt40 not R??
Posted on: 2008/10/23 9:50
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
cool thanks
yeah it will be a series 2 bluebird... wrote without thinking hard enough
Posted on: 2008/10/23 10:07
1200 Coupe Rallycar
gt40 not R??
The GT40 coil is designed to run on a standard 12 volt system, but not the High Energy systems. A coil that is designed for the higher primary voltages that these systems apparently use will be required.
Sourcing one fron a donor Series 2 Bluebird is an inexpensive way to get one that matches correctly.
Posted on: 2008/10/23 10:18
Love your Datsun.
Treat it well.
From Melbourne vic
True thats a very good point dodgeman
A coil to suit s2 bluebird would be wise,
i'm pretty sure the black coils used on the
holden hei is still called a gt40? Obviously a
higher output but.
Posted on: 2008/10/23 11:37
:Nice
(Sorry to resurrect the the thread but I thought it would be better to keep it in one place instead of starting another thread) :)
..that said, I recently received one of Mal's (Weekend1000) fantastic B310 aftermarket elec dizzys and need to check what coil is required?
Is it the GT40 or the GT40R?
Cheers,
Sam
Posted on: 2010/1/27 9:02
From Perth WA AUS
I'm running a GT40R with the same dizzy.
EDIT: Sorry, its a GT40T coil & I need the resistor to run the motor.
Posted on: 2010/1/27 9:27
Datsun 1200 2Dr sedan.
From Cape Town, South Africa
I removed my resistor and just bridged the wires, other wise it runs until you release the key on start.
Posted on: 2010/1/27 11:47
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
