« 1 (2) 3 »
Re: Ventilated stanza rotor?? Does it exist?
From RAdelaide
Thanks 1200rallycar Ill try the set up you have. Confident the ssr's i have will clear I'll let you know :)
Does your caliper stamp read s12+8 ?
Thanks everyone else too, case closed. ( I hopE)
Posted on: 2010/1/24 11:23
From RAdelaide
Found some calipers today from Oriental spares at lonsadale. Guys were really helpfull and let me go through their stock to find the right calipers
I found both S12+8 and S12w calipers but only a left for the S12+8's. So sized both up and were identical other that cast design, so i left with the S12w's.
Is it the caliper here that has to be machined to meet hub?
good thing is it all clear my 13's
jpg  s12w offset.JPG (37.67 KB)
12659_4b6290cfd20dc.jpg 360X480 px
jpg  ssrs,stanzastrut,s12w.JPG (47.04 KB)
12659_4b629193ee6fb.jpg 480X360 px
Posted on: 2010/1/29 7:43
From Melbourne, Australia
nah thats not where i machined
when i said hub.... well thats not what i meant
i meant the centre of the disc i guess, not where the pads touch but the protrusion from the centre of the disc, if you got your caliper bolt holes to line up then you clearly didnt have the same problem though, as mine did not bolt up until machining was done
although maybe thats not a problem until you put pintara discs on
edit... thought you had disc on but you dont, you will see when you do... i ordered slotted u12 pintara discs for mine... had the calipers rebuilt at brake shop too, wasnt much more than 100 for that
Posted on: 2010/1/29 7:59
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From RAdelaide
oh ok , does it look normal though to what your used to?
Just didnt know whether the caliper was supposed to be more to the right it the pic? Any way ill get some rotors and find out. guy out dba said could be a chance he could make up some 5000 series to suit once I find something that fits!!
Posted on: 2010/1/29 8:06
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
oh i see what you mean now... nah should be sweet,
dunno what 5000 series are?
defiantely u12 pintara discs on mine
Posted on: 2010/1/29 9:18
1200 Coupe Rallycar
From Perth
Theres no 2 piece (5000 series) for a pintara... all cast iron baby
Posted on: 2010/1/29 10:36
From RAdelaide
Not currently no, but when I get some measurements it may be possible.
News just in, available from ap racing
Posted on: 2010/1/29 13:05
Edited by srb210 on 2010/1/29 13:28:27
From mandurah
hey man keep us all informed about this convertion as im in the process of choosing a brake package and want to know which setup will need the most work and which will be the most effective
cheers
Posted on: 2010/1/29 14:04
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth
Why bother with $600 each for alloy hat discs to reduce weight when you put a beheamoth caliper on it ?
Posted on: 2010/1/29 15:15
From RAdelaide
ok so this looks wrong.
s12w calipers dont seem to fit rotor correctly. This is dummied up but still cant see it getting any better. Shaved a little off the bottom of the caliper so rotor is centered on stub but touches in a couple of areas.... rotor hub touches brake pad backing plate and brake pads extend past rotor. Cant see hoe s12w is a correct option. Must be the s12+8 caliper only.
I have found alot of good info for 280zx struts but im unsure whether they are the same stub axle size and whether the ears for the brake bolt up is the same distance away from the stub compared to stanza ones? anyone know? If they are i could keep the s12w's and use a 300zx vented rotor with a alloy spacer.
Posted on: 2010/2/1 11:40
« 1 (2) 3 »
