Cheap and easy HP
Hey im a newbee to this forum... Im a datsun owner, i got a 120y 2 door sedan. A12 engine no mods at all... Shes all standard except the aftermarket shifter knob...
Was rebuilt about 2 - 3 years ago.
What im after is some ideas for mods i can do to the engine without spending buckets of money. Basically i wanna get as much go from the engine as i can without spending a lot of money and replacing lots of parts. Hope someone can help !
Posted on: 2003/10/29 5:11
Re: Cheap and easy HP
From Sydney
BOOST Son BOoooooooooost !!!!!
Get someone who can wipp you up a manifold, buy yourself a GT28 rollaball bearing Turbo....... leave everything else standard maybe need a change the fuel pump ?
hehehe. pull the head gasket off, go and buy a piece of 1.6mm copper sheet, cut your self a new gasket, wack it all together and have fun.
To be honest Champ, when you work out the formula for Cheap and Easy Horsepower, let us know becuase i dont dont think any of us have found the forumla as yet, good luck looking
Cheers
Peddler
Posted on: 2003/10/29 5:19
From campbelltown (sydney) australia
i wish it was just that easy, everyone would have ball bearing turbo dattos hehe
Posted on: 2003/10/29 5:28
Hmm it would be nice.
Im not talkin about BIG HP, im just thinking of getting the most out of my engine. Theres no little tricks that can get just a tiny bit more go out of the engin? What about forcing air down the carby...? Prolly does nothing i dunno ! Lust little hints n tips im after...
Posted on: 2003/10/29 5:34
From Sydney
all good and well to want to get more air in the thing........ but getting it mixed with the correct amount of fuel is a huge help
BOOOOOOOST SON BOOOOOOOOOOST
Cheeers
Peddler
Posted on: 2003/10/29 5:38
Ok, you seem to know what im gettin at? Will it help me any? Also whats some cheap ways of doin it?
Posted on: 2003/10/29 5:46
From Sydney
there really is no such thing as cheap my friend........
Cheers
Peddler
Posted on: 2003/10/29 5:59
Quite a regular
From melbourne
buy an a15 there cheap and will give you more grunt
or cut the air cleaner box surround off and make yourself a sports air filter cheap and easy
Posted on: 2003/10/29 7:31
From Castro Valley,CA USA
Or don't cut up your aircleaner and run an air duct to the front of the car for cool air.
I think the cheapest upgrade would be an A15 from another Datsun. It should just bolt in with the exception of some easy motor mount extensions.
Posted on: 2003/10/29 7:51
Before you go looking at performance improvements, try going for the cheapest & best performance tricks. Give it a FULL tune up.
Check the compression. Thats always a good start. If your engine is down on compression then fitting twin carbs Etc. will not help much. Get the tappets correctly set, replace the points & maybee even the condenser. Set the dwell angle correctly & monitor it at about 1,000k, then 5,000 & 10,000k. Set the timing correctly & make sure that the vacuum can works correctly & does not leak. Replace ALL filters & fill with the correct grade of oil for the season & the use that you have for the vehicle. Make sure that the brakes are correctly adjusted & are NOT dragging. Make sure that the carb is correctly adjusted.
Depending on just how good or bad your car is tuned & serviced, you may find that this perks it up quite nicely. This is the baseline upon which you base further improvements, & this is abiut as low cost as you can get.
If the compression is down, then rectify the CAUSE of the problem. This usually involves the good old "ring & valve" job & is recomended before adding any performance improvements to a "used" engine.
Chris
Posted on: 2003/10/29 9:22
