« 1 (2)
Re: HELP. Electrical Problems
Yes, your next task is simple. Find out why the 12V from the battery is not getting to the fusebox. The components are:
* Battery cable
* main feed cable (attaches to + battery terminal), which goes to:
* Fusible link
* Wire from fusible link into main harness
* main harness wire to fuse box
Don't forget to check grounds, these wires complete the circuit
** Negative battery cable, which goes to the timing cover
** Main body ground wire, which goes from the battery cable to the ground spot by the horn.
When you use the test light at the fuse box, put the test light negative lead direct to the the battery for best results. Don't just check at the body, because the problem may be a ground problem.
Posted on: 2010/2/4 1:21
« 1 (2)
