« 1 (2)
Re: a12 no power at low revs
Even the little A10 engine could handle a B20 ute, with two adult passengers, a tank full of fuel & a 1/4 ton payload, so surely an A12 can handle a stripped down buggymobile.
Give the thing a proper tune up, check that the advance systems in the distributor work properly & stick a vacuum gauge on it.
At 700rpm idle it should run smoothly & pull about 19" hg of vacuum at sea level. A little less at altitude.
If the vacuum readings are seriously down, then you have a problem.
Posted on: 2010/2/7 11:30
Love your Datsun.
Treat it well.
« 1 (2)
