« 1 (2)
Re: Problem with electrical drain
So you tested it overnight? With the plug out, I predict your battery will still go dead, indicating that is not the cause.
Posted on: 2010/2/11 2:08
From Atlanta, Georgia
Yeah, I'm going to check it in the morning. The batteries hooked up, so we will see if your correct. Judging by all your other advice, I'd say you are right.
Posted on: 2010/2/11 3:45
1981 Datsun B310
1973 Honda CB175 K7 Cafe
Well, It turned over just fine this afternoon. The battery was hooked up since I disconnected the harness. It was low, but had enough amps to start.
Posted on: 2010/2/11 20:50
1981 Datsun B310
« 1 (2)
