(1) 2 3 »
engine weights
From Fremantle, West Australia
Searched the Wiki but coulnt find the weights of various datto motors
Anyone know what an A10,A12, A15 weighs?
and does this figure include the manifolds, carby, flywheel etc
Thanks
Posted on: 2010/2/16 2:41
Re: engine weights
From SE Melbourne
A12 = 87kg, A14/15 = 93...not sure on A10
Posted on: 2010/2/16 3:01
Mildman, Datsunless
Re: engine weights
http://datsun1200.com/modules/mediawi ... .php?title=Engine_Weights
A12 87 kg 192 lbs
A14 93 kg 205 lbs
A15 is same as A14. A10 is lighter than A12.
Posted on: 2010/2/16 4:43
Re: engine weights
What does an A10 weight because I think the weights are wrong
as recently someone weighed an a15 and it was around 108kg
complete.
The a10 bare is I reckon about 65kg as I picked one up the other
day and it was easier than picking up my nephew the fat blob.
Posted on: 2010/2/16 4:45
Re: engine weights
It depends on how they were measured. With flywheel or without? With starter, alternator and air cleaner, or without? With oil in the sump or without?
Posted on: 2010/2/16 5:02
Re: engine weights
a15 lighter than an L18 thats for sure but L18 easier to pick up as easier to grab onto. thats minus fly but with head intact and bottom ends
Posted on: 2010/2/16 5:13
Re: engine weights
From Adelaide, Australia
All those weights are inconsistant, some with accessories some without etc. I think some would even have gearboxes in those weights.
I like how a Z20 weighs that much more than a L18... they are basically a L20 but with a much shorter lighter head and rocker cover.
I think a re-weigh is needed. I think it would be best doing this without manifolds, alternator, fluid etc.
Posted on: 2010/2/16 5:34
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: engine weights
Yes, go ahead and measure them for us.
Posted on: 2010/2/16 6:11
Re: engine weights
Will see what I can do, I have A12's L16's L18's a L20 a Z24 I can measure, just need some scales first.
Posted on: 2010/2/16 6:18
IPRA Build
Re: engine weights
From Snohomish, WA USA
I would be interested to know what the Z24 weighs.
Posted on: 2010/2/17 6:13
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
(1) 2 3 »
