nuts n bolts
From Sydney NSW
i dont know if i should have posted this here or main forum but i need the bolts to link up my 56a gearbox to a14 motor and the bolts that connect the gearbox crossmember to the chasis? any thoughts? cheers
Posted on: 2010/2/15 4:55
Re: nuts n bolts
From Townsville, Qld
do you have at least one of each? that would make it easier because you could go to a specialist bolt shop or bunnings and size up replacements. The gearbox to block ones are m8x1.25 something like 70mm long with half of that unthreaded shank.
Posted on: 2010/2/15 8:48
Re: nuts n bolts
From Sydney NSW
thanks mate ill have to have another search and see what if i can find one or a few of each
if not might have another trip to the wreckers
Posted on: 2010/2/15 12:15
Re: nuts n bolts
Quite a regular
From Inner West Sydney
There's a mob in North Parramatta called The Nut House in Dunlop St. They are pretty good if you have a sample.
H.
Posted on: 2010/2/17 2:35
Im old
Re: nuts n bolts
From Sydney NSW
thanks ill check them out
Posted on: 2010/2/17 4:31
