DCNF Jetting/setup
From Malaysia
Hi guys,im wondering wat DCNF jetting u guys uses for ur moded or std engine? Juz for reference for every1.
Engine Specs
Nissan Vanette C20 A15 1500cc
Australia Regrind Cam 270⁰ 6.5mm Lift (Stock 240⁰ 5.5mm)
Skimmed Head 0.5mm
Wider Valve Angle (3⁰ - 5⁰)
Std valve clearance spec (Cold 0.30mm)
Fuel System
Weber DCNVA 36
Main Jet = 125
Air Corrector = 200
Emulasion Tube= F24
Pump Jet = 50
Idle Jet = 45
Auxilary = 3.5
Choke = 26mm
Japan Fuel Pump 4psi (Build in regulator)
Ignition System
MSD Blast 2 Racing Coil
Performance Plug Cable (Low Resistance 2k ohms)
IK20 Iridium Plug
A15 Electronic Dizzy
Ignite at 12⁰ BTDC without vacuum port
Exhaust System
A15 4-2-1 Extractor
1.6” Piping
2 Center bullet
Rimus Muffler
Posted on: 2010/2/18 1:58
Edited by ronald_loulan on 2010/2/26 6:52:15
Re: DCNF Jetting/setup
We don't use DCNF carburetors, not sure if any club member does.
Posted on: 2010/2/18 4:29
From Malaysia
i think most of the members uses twin Dcoe or Dhla...
Posted on: 2010/2/18 4:48
B110 1972 Modded A15
Or PHH40s like is the favorite in Japan.
Or Weber DGV, which is a favorite in USA and Australia.
Posted on: 2010/2/18 5:05
From Sydney
DCNF weber's are much like an IDA or IDF weber. they are a dual throat synchronous downdraught carb. I have a pair of 40DCNF's i want to try on an A-series at some pont. As for jetting i would reference the calcs and charts used to determine the jets used in DCOE webers.. I think it would give you a good starting point or baseline.
Also an added bonus for there use, would be on LHD B110 models, i reckon they would clear the brake master cylinder.
benny
Posted on: 2010/2/18 7:27
Edited by benny on 2010/2/18 10:48:56
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Malaysia
DD,in Malaysia most ppl uses DCNF(performance) or DGV(Spirited Driving)..
For racing or drifting,we use DCOE or DHLA or Solex... :)
Benny,y dont u use twin side draught??
Coz they cant clear the brake master cylinder??
Posted on: 2010/2/23 13:37
From Townsville, Qld
all of his are RHD, I'd say it's an exercise in alternate performance possibilities. And why not, they're a compact little jigger that packs enough punch for Ferarri
Posted on: 2010/2/23 14:50
