« 1 ... 3 4 5 (6) 7 »
Re: datto ute handling (or lack of)
as long as they are installed correctly and just not with the grub screws (ie welded a colar top and bottom like you did piggy) they are insattled securely and have as much likely hood of cracking as other alloy ones.
steel ones, if fine thread can have similar issues.
Posted on: 2010/2/17 22:10
From Melbourne,Australia
Good to see your getting some track time in ange.Im about to pull the y off the road for a few suspension mods myself hopefully il be able to join you on a hill climb soon Where are you racing on the 7th? Haunted hills? Mite come down for a look
Posted on: 2010/2/17 23:07
From Melbourne Vic
i wanna see a pic or hear actual experience of someone who has had the grub screw alloy sleeve type coilover fail! the grub scres tightens the collar so that it can't screw up or down, it actually allows you to run your car lower due to only being a single collar. for $200 us you can have a coilover kit with a spring in any rate you choose and any height spring you choose from a reputable company, unless of course you are a victim of the dreaded internet story gospel and need to avoid alloy (of which all collars are anyway!)
Posted on: 2010/2/19 16:24
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From ACT Aus
sssute isn't yours irs but making it a little hard to compare?
Posted on: 2010/2/20 0:19
unfamilia wrote:
You have bump stops? Your soft
From brisbane
Hi Andrew
Great to read your first hillclimb went well.
Apologies if you have been emailing me lately. My home laptops (yes 2 of them) both died so I am using my work laptop to log on today. I can't get my personal emails on this one however.
As has been mentioned soft in the rear is ideal. Koni make a bolt up rear shock in the internally adjustable Red range which works well. I run this shock on full soft after trialling several settings.
I think I have provided you with my specs previously but if not just let me know.
Well done mate
Matty
Posted on: 2010/2/20 22:43
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From Melbourne AUS
ok so im planning to shorten my 120y struts with new inserts and a coilover kit so i can keep my s13 brakes and that should see the front sorted.
i wont have time to get all that done by the 7th so ive switched to gemi springs up front and they are a heap stiffer than the king springs i was using. the front has a little bounce in it becuase of the soft shocks but its already turning in a heap quicker and sitting a lot flatter through corners than it was before. so im confident that its improved somewhat already...
ive taken out the load leaf on the rear springs, which seems to have helped also, but i dont have a lot of travel in the rear now
as the rear sagged a little without the load spring and theres not much clearance to the bump stops. so ill try and get more travel in the mean time also...
Stu im back out at Haunted Hills on the 7th to see if i can better the 64.26 i did last time.
anyone care to join me?
Posted on: 2010/2/21 4:25
1973 B110 A12
i wish but no car or $$$. what if you put load spring on top ange to leave the rear soft but will stop it hitting the bump stops (would hate that mid corner)
to give you an idea im using 240z gas shocks with 190lb springs and they are pretty well matched. (mind you they are only $30 ebay gas shocks) but they work pretty well for $30 and are readily available.
doubt they would fit your strut tube. there must be somethime short ebough and factory to suit your needs
Posted on: 2010/2/21 8:53
From Melbourne Vic
you'll be limited in shock choice if your 120y struts are the skinny ones, but you can put a big tube on the small stub axle, pm sikyne for details
Posted on: 2010/2/22 2:58
Re: datto ute handling (it sorta does now!)
From Melbourne AUS
a bit of an update...
i removed the load spring from the rear to soften it and put in some gemini coils up front to stiffen it.
so ive only changed spring rates in a quick fix for the next track day which was yesterday.. and it seemed much better.
although little hard to compare as i was on a wet track this time but i did run a second quicker on a drying but still damp track than i did last time in the dry. so happy with that.
next step is new adjustbles in the rear, and a shortened coilover strut up front with more camber. needless to say i had a ball once a again..
some pics
(more camber needed)
who wants to join me?
Posted on: 2010/3/9 10:01
1973 B110 A12
pick me pick me
looks a lot flatter in the corners front and rear now, especially rear.
like i text you, probably smoother lines and driving by being caustios in the damp than you were in the dry. Pushing harder in the dry might have made you loose time.
looks like fun and i cant wait to sort mine out to get it out there once or twice too.
glad to see your planning next one already lol
Posted on: 2010/3/9 10:08
