« 1 ... 4 5 6 (7) 8 9 10 ... 15 »
Re: GUESS THE H.P........... BIG PRIZES FOR CLOSEST GUESS!!
From Geelong, Vic
normal 4 cylinder cometic price is about $80 give or take....$230 plus shipping seems like the prices they are in oz
Posted on: 2010/2/20 10:52
From Ballarat Victoria
I could have spent $250 on a head gasket but i had to draw the line somewhere. At the moment i think the pistons and the $18 head gasket are on par for robustness. It would be a whole different proposition with a good set of pistons and head gasket.
At the moment im actually more worried about the pistons. Time will tell.
Posted on: 2010/2/20 12:10
VIC DYNO HIRE
Sorry Pigdog, i missed your post. I looked at the Cometic website and they didnt list one for the "A". The price i was quoting was for diferent brand, Still a multi layer steel one tho.
Posted on: 2010/2/20 12:15
VIC DYNO HIRE
From SE Melbourne
Just remember with your guesses, its a stock engine! except for valve springs and head studs. Im loving the optimism tho!
...it's still also turbo charged right?Quote:
Here are the engine specs. -A12 bottom end. Totaly stock including cam and not rebuilt except for a light hone and a new set of cast rings.(may have dry sump sys.) -Standard A15 H89 head, untouched ports and standard valves but with double valve springs. -custom turbo manifold and inlet manifold. -Fuel injected and intercooled. -E85 fuel -Garrett turbo. -3" exhaust, no silencers. -Boost? as much as i think it can reliably handle! (15psi+)
Posted on: 2010/2/20 22:20
Mildman, Datsunless
From bendigo, vic
139.5hp atw cheers blake
Posted on: 2010/2/21 1:58
theres no substitute for forced induction
Yes Mildman, All the original specs are still the same. Ive added head studs tho.
Posted on: 2010/2/21 11:37
VIC DYNO HIRE
From Christchurch
Hey sikyne, have you seen this software here? Not sure if its any good but just thought i'd post it up for you
http://www.dtec.net.au/Dynertia%20-%2 ... 0Dynamometer%20System.htm
Edit: ah crap wrong thread, that was meant for the dyno one
Posted on: 2010/2/21 20:21
Thanks for the link Nick, i`ll send you a PM.
Posted on: 2010/2/21 23:54
VIC DYNO HIRE
HA Ha , Do we have members getting a second user name to try for the $100.
1200turbo is looking a bit sus!
BTW. Welcome to the site and good luck if you are new!!!?
Posted on: 2010/2/22 1:01
VIC DYNO HIRE
i have nearly exactly same specs, i reckon 143.8hpatw...Cheers
Posted on: 2010/2/22 5:32
