« 1 (2)
Re: why does my A12 feel faster than my A15 in 1000 ute?
From Adelaide, Australia
feel as in i dont have a dyno :P.
Posted on: 2010/2/24 9:53
parts needed: GX air filter box. for sale, stanza steering wheel, 1000 gloveboxes lids
My skateboard feels faster than my ca ute ;)
Posted on: 2010/2/24 9:58
im more getting at what i should build. the car feels so light that anything i stick in it will go well but what will suit my purpose better. a turbo'd E series or a hi revving A series. i just feel the Eseries giving too much power ( as in wheel spin) but not enough revs while the A series will have less power but rev much more.
Posted on: 2010/2/24 10:03
From Geelong, Vic
so whats stopping you from building a high reving E series? or a turbo'd A series?
have the best of both worlds
Posted on: 2010/2/24 13:31
Eventually you will opt back to the beauty, simplicity and originality of the A series.
The e series is nice but although you can solve the dizzie problem with ecu ignition the
water passage to the back of the head is not aesthetically pleasing or rather ugly.
Since the bolt up is similar to a qg18de or ga16de you might find them better again
if going the e15 path. In Canada and Europe there is a ga16e with 12 valve head that
is supposed to be a midrange king with fat torque and great economy.
Very compact 12v sohc head design and it bolts up to the 1.8 liter gq18de block.
http://www.nissanforums.com/b11-b12-k ... eurocam-install-here.html
After many years the best bet is a boosted SU setup A series similar to Topgear
but with proper carbon sealed turbo, meth/water injection, jet coated exhaust
and adjustable in cabin boost controller for the feel/power you desire.
All using stock A12 with a14 crank, e15et pistons and a12a conrods.
Posted on: 2010/2/24 14:17
From pooraka,,adelaide
matto dont u have the a12a . . ? isnt that the exuivelent to the a13? like the imports?
Posted on: 2010/2/24 22:33
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
What about an A18, just fit a 1" thick plate on top of A15, dry liners, longer rods & pushrods and there you go. And the stroke is still shorter than GM V8, so should rev to 8500 RPM or so.
Posted on: 2010/2/25 0:52
Theres also the Ca18de route and plenty of gearboxes available.
Also the a12 block with a14 crank, a12a rods and offset 81mm sleeves
and 81mm 4AGE slugs will give you 1587cc with meat left over for boost.
Posted on: 2010/2/26 4:27
what have i started lol.
ive been looking at what i already have and what i can do and i think ill fit edis on the E15 and make it suck through turbo as i cant join edis and the original ecu together. ive also got some forged pistons to suit the E series so im hoping i can get a bit of power out of my setup.
Posted on: 2010/2/27 9:22
go with EDIS and Megasquirt and blow through EFI?
Posted on: 2010/2/27 13:23
« 1 (2)
