#1 anybody ever adapted ford EDIS to a 4cyl?
Matto1kUte Posted on: 2010/2/24 10:30
hey guys has anybody ever adapted ford EDIS to another 4cy motor? i know it can be done but i dont know anything about it. can anybody help?
#2 Re: anybody ever adapted ford EDIS to a 4cyl?
1200rallycar Posted on: 2010/2/24 11:35
megasquirt guys love it, jump on their site/forum and you will discover all!
#3 Re: anybody ever adapted ford EDIS to a 4cyl?
ddgonzal Posted on: 2010/2/25 1:05
Megasquirt costs a lot if all you want is crank-trigger ignition.
Here's my 1200 with EDIS:
#4 Re: anybody ever adapted ford EDIS to a 4cyl?
Posted on: 2010/2/25 1:16
love that brake splitter, wish ours were as quality as that one
#5 Re: anybody ever adapted ford EDIS to a 4cyl?
D Posted on: 2010/2/25 2:31
DD can you show us the coil packs or is that old black tin can it? :))
#6 Re: anybody ever adapted ford EDIS to a 4cyl?
racinaround Posted on: 2010/2/25 5:02
#7 Re: anybody ever adapted ford EDIS to a 4cyl?
ddgonzal Posted on: 2010/2/25 6:28
Your wish is my command. I ended up mounting it here on the core support next to the radiator:
Can somebody help me make the wiring look nice?
For late 1200 utes, with the battery in front, the stock coil location works well:
The Ford coil pack is designed to mount on the Kent cylinder head, so I think mounted directly on the A12 and use short plug wires would be the ultimate. But I couldn't figure out how to make a bracket for that. I'm not good at fabricating things, but figured out how to do this EDIS install.
Almost 2 years now, still runs perfect. A rock-solid idle is the most noticeable thing.
#8 Re: anybody ever adapted ford EDIS to a 4cyl?
TJ-Flames Posted on: 2010/2/25 6:41
so what is the difference in using the edis compared to the stock?
#9 Re: anybody ever adapted ford EDIS to a 4cyl?
ddgonzal Posted on: 2010/2/25 6:58
* It is electronic -- no points
* It is hotter spark than Datsun electronic ignition
* It produces a rock-solid idle, probably because there is no gear lash and other play as in the distributor
* New vacuum advance unit is $75 (and most are broken), I have $120 in this setup
* I can tune the mechanical and the vacuum advance with a laptop
So far I've only got the A12 stock map, haven't experimented with extra timing.
This would be great for E15 or GA16 with rwd 5-speed.
#10 Re: anybody ever adapted ford EDIS to a 4cyl?
supafatto Posted on: 2010/2/25 8:07
dd do you think this would be a good option for a turbo or supercharged if it is tuneable??
(1) 2 3 »
