Re: Rocker Cover breather --> Block breather..what will happen?
The one thing it won't do is "(pom ) sound then all dead"
To resolve this problem (pom sound then all dead), start with the basics, your basic tune-up procedure
* Compression test
* Timing check
* Spark test
etc.
Posted on: 2010/2/22 21:29
finally i found the problem... the conrod burn duh.. the engine oil empty.. ( leaking i guess ) so will it be other thing like bearing, valve, piston n etc to be problem as well ??
so will it better i rebuild this a15 or find another a15 engine i think it will cost alot to rebuild rite ???
Posted on: 2010/3/2 3:02
« 1 (2)
