What wright oil should I run in a 56 serise gear box?
From Canada, B.C , Richmond
Was just wondering what everyone runs. I have a few bottles of 75w 90. Or should I go 80w?
Posted on: 2010/3/3 2:21
Re: What wright oil should I run in a 56 serise gear box?
From pooraka,,adelaide
im not too sure but i have always ran 80w 90
same as in all my diff's
Posted on: 2010/3/3 3:13
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
75W-90 is better the 80W. It is both lighter weight and holds up to the heat better.
Go for it.
Posted on: 2010/3/3 5:30
From NZ
Ensure it's GL-4 not the later GL-5 or synchros will 'crunch'
Posted on: 2010/3/3 10:35
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Really? Anyone else have problems with GL-5?
Posted on: 2010/3/3 17:42
Yes, many people have reported problems with GL-5 gear lube in their older cars. The problem won't be immediately evident but over time the synchros will wear down.
Note that GL-5 containers do not say it is compatible with GL-4. Compare that to engine oil, which generally says it is backwards compatible.
Nissan specifies GL-4
Specification: API GL-4 MIL-L-2105
Posted on: 2010/3/3 20:53
