Week End Stuff
From Sri Lanka
Hi Guys
Just spent my week end with Car wiring, pulled the wiring that runs here and there cleaned them replaced old corroded ones with new wires, so every thing is fine working correctly, the car is very clear and clean under the dash, but my brake lights are always on even i have not switched on my key , what would be the reason ?
Thanks
regards
sumith
Posted on: 2010/3/3 5:59
Re: Week End Stuff
The usual reason is that the switch on the brake pedal is not adjusted correctly.
The rear brake light circuitis always powered -- it does not depend on the IGN key. But normally they are OFF because the brake pedal is all the way up.
Posted on: 2010/3/3 6:14
Re: Week End Stuff
From Sri Lanka
Hi DD
I think i have mislead you sorry, actually it is not the
brake light, it is the light that glow when you put lights on or parking on .
Thanks
Regards
sumith
Posted on: 2010/3/3 6:19
Re: Week End Stuff
From Sri Lanka
Hi Guys
Found the problem that was the Light switch that contact 2 wires together to blow my tail light always,sorted it out so happy on it, now i want to solder my brake light switch to the paddle a i don't have one, i bought the switch don't know how to solder it can any one post me a way or a picture would be worth billions,bench tested it as i understand when the switch nob is pressed it stops voltage going through it , so the brake light should be given two 12 V wires that doesnot blow it untill the paddle is pressed down ? isn't it ?
thanks
regards
sumith
Posted on: 2010/3/8 4:18
Re: Week End Stuff
Which switch are you asking about? Where is it located?
Posted on: 2010/3/8 5:00
Re: Week End Stuff
From Sri Lanka
Hi DD
The Switch that engage when you push down the brake to blow behind brake lights
Thanks
Regards
sumith
Posted on: 2010/3/8 5:02
Re: Week End Stuff
OK, that switch turns on the rear brake lights. 'Blow' is a term I haven't heard before in this context.
What do you mean by 'paddle' do you mean the brake pedal?
You can see the brake swich in this photo. It screws into the sheet metal like so.
Posted on: 2010/3/8 5:15
Re: Week End Stuff
From Sri Lanka
Hi DD
Yes it is the brake paddle i meant, the picture is clear thanks a lot i wanted to know how you hook the brake switch ,next week end also i might have a go .so when you press the brake paddle down it will depress the switch nob and deliver 12 v to the bulb ?
Thanks
regards
sumith
Posted on: 2010/3/8 5:38
Re: Week End Stuff
No, it normally pressing on the switch.
When you push the pedal with your foot, it comes off the switch.
Posted on: 2010/3/8 6:02
