Probably the cheapest way to lower compression that Ive seen is by using these sparkplug
sleeves that screw onto the spark plug thread and place the plugs higher up in the tube.
Its kind of a pre-combustion chamber. I remember some old wheels magazines and later parts
trader mags advertising them in NSW - they where supposed to increase gas mileage.
If you can get them made by drilling some big bolts in the centre and taper the entry like
a funnel and on the opposite end a thread to place your sparkplug into then you are set.
You can calculate the amount of extra displacement by liquid measuring the amount of
fluid from a syringe that these sleeves take with the plugs screwed on.
Has anyone ever seen these things for sale in NSW or elsewhere via mail order from the old wheels magazines?
Its a type of glow plug similar to these smartplugs.
http://www.smartplugs.com/about.htm
You can always try singh lines :)
[url=http://www.gassavers.org/showthread.php?t=6465]http://www.gassavers.org/showthread.php?t=6465
