« 1 (2)
Re: Is my bluebird diff a LSD?
From Melbourne, Oz
depends on the sort of LSD, I asume a nissan bluebird has a cluch pack type? in wich case it will lock like dodgey sed, unless it is absolutly nacked!
Posted on: 2010/3/8 5:34
"I hav achieved wood"
From Taupo New Zealand
it won't 'lock' at all. When you set the breakaway torque of a clutch LSD you check it by measuring it with a torque wrench. An unmodified datsun LSD will probably only have a breakaway of about 50ft/lb. With the leverage of the diameter of a wheel you can turn it fairly easily if you try.
If it locked up I'd be looking for broken parts inside jamming it up
Posted on: 2010/3/8 5:46
1970 1200 coupe A15
1972 1600 original except for nana's sheepskins
1978 B310 SR16VE
From Nations Capital, Australia
So it wasn't i stupid question then!! haha.
Posted on: 2010/3/9 10:38
course not. the only stupid question is the one that didn't get asked as they say.
Posted on: 2010/3/10 9:47
1970 1200 coupe A15
1978 B310 SR16VE
You are correct when you say that once the drag of the clutches in an LSD is overcome, then the oposite wheel will turn the opposite way if the pinion is prevented from turning as this type is really a 'spin resistant' diff. However if you can do this by hand, then the clutch packs are totally shot & you effectively have an open diff.
Posted on: 2010/5/30 0:49
Love your Datsun.
Treat it well.
« 1 (2)
