Stanza strut swap Q
From Adelaide
Simple question, I hope
Swapping in the (shortened) stanza bits into an 85 ute. The 2 bolts that hold the steering arm (knuckle) to the strut, does anyone know the size, length, pitch?
Or can I remove and reuse the ones that are in the 1200 struts?
Cheers,
Jake
Posted on: 2010/3/9 10:40
Re: Stanza strut swap Q
From Townsville, Qld
Hmm, being a later ute I'd be inclined to think you can. I'm just trying to remember if my 77 120y was like that when I put the stanza struts in.
Posted on: 2010/3/9 10:47
From Geelong, Vic
edit, so you have stanza steering arms in it and you just need the bolts?
original ones cant be reused as they are studs not bolts
Posted on: 2010/3/9 10:56
From Adelaide
^ yep, stanza struts and steering arms. No visible means of joining the two.
I have no access to either of them (or the ute) at the mo, so I cant go have a look either.
PS New to datsuns, but not cars.
Posted on: 2010/3/9 11:18
From Geelong, Vic
yeah they use bolts in the larger struts. they are the same size and pitch as the caliper bolts im pretty sure
easy enough to pull a caliper bolt out and test it. think the caliper bolts are longer though
Posted on: 2010/3/9 11:24
From Adelaide
sweet, thanks mate.
Posted on: 2010/3/9 11:27
