« 1 (2) 3 4 5 6 »
Re: Datoboys 1200 Coupe Project
From Newcastle nsw
if you guys are interested in em, i can get them for you if yas like. the top plate you drill out to suit what struts ur using, and you may need to machine up a lil spacer to go between the top plate and ur strut top. These also have helper springs included in the kit and addition springs available for $99 a set!!
Posted on: 2010/3/9 12:24
From Geelong
I might have to keep you in mind datoboy!
Posted on: 2010/3/9 12:32
From Maraylya nsw
i will keep that inmind too
what struts do you plan to use datoboy?
Posted on: 2010/3/9 12:35
sr20de out of s13 written of silvia under way
making progress on the 1200 coupe;)
From Newcastle nsw
no dramas, just let me know whenever ya want some. it took em like 3 days do have em on my door step. postage may be a bit more cause ill have to resend them to you, but should be more than $15ish on top.
P.S!! Im not makin a cent out of this, but i looked for agaes tryin to find some of these so thought might help others out too.
Available in 45mm, 48mm, 51mm and 55mm internal diameter, each kit includes two sleeves, two spring seats, two lock nuts, two main springs, two helper springs and an upper spring locator.With this kit you can choose any spring rate between 4kg/mm and 8kg/mm (except for the 55mm kit, 6kg/mm only). then other springs rates can be ordered. rrp $299 + postage
Posted on: 2010/3/9 12:38
From Geelong, Vic
not a bad price, pretty similar to what the T3 ones would be shipped i guess
Posted on: 2010/3/9 12:40
From Newcastle nsw
ive got sunny or stanza struts, cant remember, but they were in the car when i got it. Gotta shorten the tubes about 3 inches, and find a suitable insert yet. will post pics in the next few weeks of them fitted.
From Maraylya nsw
that sounds really good for that price!
so what are your plans for struts and brakes?
i tend to use stanzas with 200b girlock callipers and a coil kit eventually blah blah
should work
Posted on: 2010/3/9 12:42
From Newcastle nsw
http://www.otomoto.com.au/HDSystems/sleevekits.htm if you wanna deal directly with them
Posted on: 2010/3/9 12:43
From Newcastle nsw
yeh i got girlocks of a hx holden on mine lol, but i also have some s13 180sx rotors (280mm?) and calipers layin around and also some 300zx 4 potters, so will just wait and see. Wanna run 13's though so not sure what im doin yet
Posted on: 2010/3/9 12:46
From Maraylya nsw
sounds good
i hear r31 inserts give you good travel and fit in
Posted on: 2010/3/9 12:48
« 1 (2) 3 4 5 6 »
