Re: 1974 b210 brake problems
yeah ive tried that too alot and have no leaks
Posted on: 2010/3/9 5:27
From West of Seattle
Check the brake hoses, also.
Posted on: 2010/3/9 7:55
i've checked all of the hoses that I can think of but if you know any that break more often maybe ill double check thanks
Posted on: 2010/3/10 1:13
From Las Vegas USA
Get a mighty-vac or another brand of bleeder and back bleed the system.
Tom
Posted on: 2010/3/10 3:50
You need to check the brake hoses for swelling under pressure (lose shape when brake is applied) but do not leak. Thier should be three brake hoses one on each front caliper and the third attaching the axle to the hard brake line on the body. I bring this up due to having the same problem your having on a repair of an older vehicle, I had put in all new hydraulics (calipers, pistons, master cylinder) as per customers request, I pressure bled them, no luck. In a panic I changed out the brake booster (at my cost), no luck. It was the stupid hoses swelling! I hope this helps you out.
Posted on: 2010/3/10 5:53
ok thanks guys this weekend ill make sure to double check all of my brake line/hoses and then if that doesn't turn anything up I'll use the mity-vac to try to suck some out. Thanks
Posted on: 2010/3/11 4:08
« 1 (2)
