« 1 ... 4 5 6 (7)
Re: datto ute handling (it sorta does now!)
From Geelong, Vic
i can see you going out on the track mik and suffering lots of understeer then blaming the engine weight or suspention setup
Posted on: 2010/3/9 10:23
nah will blame those 155 70 13's up front and suspension.... would never blame my cr@p driving
Posted on: 2010/3/9 10:24
From Melbourne AUS
looking at the first pic i reckon a shorter strut would have that front left off the ground... and more camber is definately gonna help with a little understeer i had at times..
dont think it was a case of pushing too hard in the dry mik, as last time i couldnt push hard as it was too busy doin one leggers around the bends
i havent planned next one yet, would like to tackle a small circuit..sandown or winton perhaps then move on to phillip island..
i think im addicted
Posted on: 2010/3/9 10:28
Edited by ANGE on 2010/3/9 10:55:58
1973 B110 A12
i think the sedan needs to be dedicated race and tow it there in the ute ;)
Posted on: 2010/3/9 10:39
From Melbourne, Australia
dont forget castor... cheap and very effective!
Posted on: 2010/3/12 7:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Perth WA AUS
WTF?
Posted on: 2010/3/12 8:15
Datsun 1200 2Dr sedan.
From Gold Coast, Australia
Koni red 80-1905 adjustable rear shocks. $290cost (RRP $356)PAIR.
just bought myself a set and might be of use too you guys.
Posted on: 2010/4/13 12:37
From Sydney
Ange, if you are going to stick with the 120Y struts /S13 brakes setup, I would probably go for the P30 bilsteins. look up a bilstein insert for a MK1 golf, there 4 options from memory, ranging from comfort street to race. From memoery they are approx $195 US ea online.
I am running KYB's [from a MK1 Golf] in 120Y struts on my sedan, matched with single taper king springs, They have an exponential rate instead of the typical linear springs.
Also, as rallycar suggested, you can never have too much castor. I run approx 4 to 5 degrees in the streeter and 6-7 on the track car. Makes for excellent straight line stability and loads the steering up nicely on cornering
cheers
benny
Posted on: 2010/4/13 14:13
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
« 1 ... 4 5 6 (7)
