are manual and auto tunnells same
From BlueMountains NSW
Gday toying with idea off puting an auto/trans into a spare 120y manual coup I have for my daughter.Do they fit.
Cheers Bazz
Posted on: 2010/3/14 12:09
I DON'T LIVE IN THE PAST....I JUST TAKE DAY TRIPS
Re: are manual and auto tunnells same
From Maraylya nsw
i know in 1200's that they auto tunnels are bigger
so i assume it may be the same with 120y's
but 120y's have a 5 speed compared to the 1200 4 speed so maybe
for sure someone else could give you a defiant answer i may be wrong
Posted on: 2010/3/14 12:17
sr20de out of s13 written of silvia under way
making progress on the 1200 coupe;)
Gday Andy I wish they came standard with 5 speed but the 74 and 75 only have 4. At least the only buggers I have do
cheers Bazz
Posted on: 2010/3/14 12:39
B210 only has one tunnel size.
Posted on: 2010/3/14 17:12
From West of Seattle
Some years back I put a dogleg from a 78 B210 I had wrecked into a 74 B210 I had picked up. I had to drill out the tunnel (tap welds) the later models must have a larger tunnel.
Posted on: 2010/3/14 17:23
Yes, the crossmember mounts are different between 4-speed and 5spd/auto.
Posted on: 2010/3/14 18:41
