Tranny interchange?
From West of Seattle
I am not very good at this interchange info. Would a 63A#2 dogleg out of a 77 B210 w/A14 fit into a 79 210 w/A14?
Posted on: 2010/3/18 5:09
Re: Tranny interchange?
Yes, all A-series transmissions. It's a lot heavier then the B310 5-speed though.
Posted on: 2010/3/18 5:49
Quite a regular
From Christchurch, New Zealand
I fitted a 63 box to my 1200 coupe. The transmission tunnel needs to be gently "massaged" to get it to fit in and a small hole made for the reverse light sender
Posted on: 2010/3/19 20:12
From Tamworth , NSW
seeing the title of the topic i was expecting something.....freaky.
the 63 boxes are hydraulic clutch arent they?
may require a clutch master too.
Posted on: 2010/3/19 21:53
From Vancouver, Wa
yes it will fit in the 79 210 the trans tunnel is large enough. the hard line for the clutch slave cylinder will need to be changed or modified, do to it being on the opposite side of the transmission. use the hard line out of the b210
Posted on: 2010/3/20 5:36
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
Yes, B210 and B310 have the same size larger tunnels than B110. So no worries.
Being as 210 is the USA version of B310, they all have hydraulic clutch.
Posted on: 2010/3/20 6:34
From sydney australia
You're probably going to need a longer speedo cable, as the 63a tranny has it on the left side & the 60a on the right.... sorry forget this, as the car is left hand drive, the speedo will probably too long, but you could just re-route through the engine bay to take up the excess. Here in Australia I'd say you'd need the speedo cable from a Japanese assembled Stanza, which was sold in America as the 510. Its model number is the (P)A10. You'd also need the correct clutch plate from the B210 as the input splines are different & probably the B210 tailshaft as the output spline is different. I've got the same transmission in a 210/Sunny, but it's the L series box behind an L18. the gearbox crossmember from an auto 210 is an alternative if the B210 crossmember isn't right.
Posted on: 2010/3/20 7:40
