Browsing this Thread:
1 Anonymous Users
best way to get power steering? |
i own a ca18det datsun ute, i bought it less than a week ago. im not too mechanically inclined, but i know i dont like using two hands everytime i turn right at a round about. so whats involved, parts, labour, cost the lot. im based in nsw, thanks/mik.
Posted on: 2010/3/18 5:57
Re: best way to get power steering? |
From Brisbane
lift some weights
Posted on: 2010/3/18 8:15
From Melbourne, Oz
HAHAHA gold.
Posted on: 2010/3/18 8:29
"I hav achieved wood"
From south coast nsw
pump ur tyres up to 60 psi!.front tyres are to wide or the steering setup will make it feel heavy, what size tyre u running?maybe put an a12 in it
Posted on: 2010/3/18 8:43
From Nations Capital, Australia
That sounds odd. All my utes, albeit stock ones, are really easy to steer. Especially when its rolling. Maybe get your steering checked out at a steering place.
Posted on: 2010/3/18 9:23
From Ballarat Victoria
Power steering will not be be the answer.
I`d replace the idler arm bushes with urethane, use plenty of the grease that comes in the kit.
The biggest problem will probably be the caster setting. too much caster will make the car very heavy to steer.
And as already said, check your tire pressures. up to 40psi is ok.
Make sure all the tierod ends and the drag link are good aswell.
Posted on: 2010/3/18 9:44
VIC DYNO HIRE
From Melbourne AUS
what size tyres do you run up front?
i feel a big difference between running 175's up front compared with 195's
Posted on: 2010/3/18 10:49
1973 B110 A12
run ouny 155's or 165s up front like me, easy as to steer.
Posted on: 2010/3/18 20:32
From Coondle, WA Australia
I dont think that the 1200 anywhere in the world ever came with a power steering unit. Its possible that the Japenese may have done so (they have a go at everything), but certainly nothing here in australia.
With much nashing of teeth and removal of hair, you could make comething fit from somthing else. That would entail custom everything to fit an alien steering box, power steer pump,idler pulley, extra groove on the crank pully (a/c pulley would work), mount brakcets. hmm pretty extensieve job really, when the comments made by sikyne would be the first port of call.
Dont think anyone on this forumn has done it, cause the utes are not too heavy in the big picture. My first car was a SWB patrol with no power steer, and 12.5" wide tyres and Im a skinney bugger.
Posted on: 2010/3/18 22:16
Registered Users Contentmaster Usermaster
Who cares? Datsun 1200 doesn't need power steering. The factory never had it as an option, not even for the utes.
Posted on: 2010/3/19 2:03
