Re: So what! Who cares?
From West of Seattle
figures, I do have another rear assembly though :)
Posted on: 2010/3/17 15:15
Leather dash installed
jpg  Datsun1 035.jpg (68.68 KB)
11027_4ba4007215116.jpg 314X235 px
Posted on: 2010/3/19 22:53
From hastings,vic
i have reused crush tubes before
mesure length of tube,record
place tube over steel bar
lightly hit tube were bulge is all the way around evenly
remesure, .5 to 1mm longer would be good
reinstall crush tube and set pinion seal/bearing preload
otherwise bearing preload could be to tight(seize bang)
to loose seal fail,leak oil,whine,crown wheel to pinion depth
will change .
can also use shims between tube and bearing
tommo
Posted on: 2010/3/20 6:29
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
Sounds like a plan, thanks for the info.
Posted on: 2010/3/20 14:59
From Seattle ,WA.
so what are crush sleeves made out of, any spec's on them? maybe they could be fabbed.
Didn't realize you were a neighbor Eric, everyone else except DD & Ernie are light years away.
Posted on: 2010/3/20 15:32
« 1 (2)
