#1 datsun 200b brake booster n hydrulic clutch fit a datsun 1200 ??
datto13b Posted on: 2010/3/21 9:28
hey guys just wondering if anyone knows if a 200b booster n clutch will fit a datto 1200?
#2 Re: datsun 200b brake booster n hydrulic clutch fit a datsun 1200 ??
dattoman_1000 Posted on: 2010/3/21 9:33
Why do you want a hydraulic clutch ?
#3 Re: datsun 200b brake booster n hydrulic clutch fit a datsun 1200 ??
datto13b Posted on: 2010/3/21 9:37
as i have a 13b weber and think i need to upgrade?
#4 Re: datsun 200b brake booster n hydrulic clutch fit a datsun 1200 ??
ddgonzal Posted on: 2010/3/21 16:27
Doubtful if it will fit. Datsun 1200 needs a small diameter booster.
B210 booster will fit
LA/LB booster will fit
B310 booster will fit with some modification
But booster is not needed when you fit a more powerful engine.
#5 Re: datsun 200b brake booster n hydrulic clutch fit a datsun 1200 ??
PIGDOG Posted on: 2010/3/22 0:06
they are the same diameter as b310 booster but a bit longer, anything can be made to fit but a 200b booster wouldnt be my first choice
clutch master can fit, but better off using one that you can mount inside the car off the stock pedal
