« 1 (2)
Re: what diff is this?
From Adelaide, Australia
Check the ext housing seal is intact in the rear of the box where the tailshaft goes in, they are only about $10 new if you want to replace it. Clean up the yoke (slides into gearbox) grease it up and go for gold, might need to give it a twist to get teh splines to mesh. Then bolt the other end to the diff centre.
If it won't go in to the box you may have the tailshaft, ie might fit the diff but could be stanza or something so won't fit the box.
Posted on: 2010/3/23 12:00
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Sydney NSW
it says 120y on the tailshaft so was just guessing it was from 120y but ill take a photo tomorrow if i cant get it in.
might need another tailshaft
Posted on: 2010/3/23 12:11
120Y came with three different tailshaft
* H145 for early 120Y
* BW for Australia-produced 120Y sedan
* H150 for others
H150 uses same yoke as H165
Posted on: 2010/3/23 16:23
From Sydney NSW
had another go today with success! got the tailshaft in, as whitesedan said really needed to clean the yoke (was fairly rusty) cleaned it up and it slid right in. also the ring and the bolts lined up perfectly with the diff so could it be a h150 from a 120y?
took some photos of the tailshaft aswell.
thanks
jpg  DSC00301.JPG (39.32 KB)
12278_4ba98db32ce8d.jpg 647X611 px
jpg  DSC00302.JPG (55.98 KB)
12278_4ba98dc560cac.jpg 829X625 px
jpg  DSC00305.JPG (51.76 KB)
12278_4ba98dd8735fd.jpg 829X621 px
Posted on: 2010/3/24 3:58
Flange
H145: 35 x 50 mm bolt holes. 38mm inner circle
H150 Wild guess: 50 x 60 mm. Inner circle 50 or 60mm
H165 guess: Same as H150 ???
Posted on: 2010/3/24 4:07
From Sydney NSW
bolt holes were ~50mmx60mm
inner circle was ~57mm
Posted on: 2010/3/24 4:28
From Bendigo, Victoria
Some years ago I put a 120y shaft in my ute, found when I put a load in or went over a big bump the shaft went right in and rubbed hard against the seal on the rear of the gearbox. Some tailshafts are slightly longer than ute ones and although they fit whilst the ute is stationary , can rub when driving. I put pictures up for Pepper a few months ago showing the different lengths.If you care to look back I think I put it under the heading "PEPPER LOOK"
Posted on: 2010/3/24 4:40
From Sydney NSW
cheers ill check it out
Posted on: 2010/3/24 4:47
« 1 (2)
