Good deal? Turbo kit $399
Is this a good kit?
http://cgi.ebay.com/ebaymotors/ws/eBa ... iewItem&item=270461001191
Datsun 1200 T3T4 TurboCharger Turbo Kit
jpg  temp.jpg (96.84 KB)
174_4bad9fb487581.jpg 799X514 px
Posted on: 2010/3/27 6:03
Re: Good deal? Turbo kit $399
From Tamworth , NSW
all that for 400 us??
that would have to be worth it right??
Posted on: 2010/3/27 6:14
From Melbourne, Oz
thats a generic pic. they do a few turbo kits and all have the same pic.
Posted on: 2010/3/27 6:19
"I hav achieved wood"
More specifically the advert lists these parts:
Turbo Charger T3/T4 hybrid
Front Mount Intercooler
Universal Intercooler Piping Kit
Boost Controller
Slim Cooling Fan
Electronic Turbo Timer
10 Meters Heat Wrap
Stainless Downpipe 2.5"
High Flow Intake Filter
High Flow Breather Cap
Coolant Sensor Bung
Non-divided T3 Flange
Posted on: 2010/3/27 6:22
From Geelong, Vic
just a universal kit, not really that good for a 1200 i wouldnt think with that size turbo
not really bad value though considering other typical ebay prices(AUS)
turbo $300-350
cooler $180
universal cooler piping $100??
temp adaptor $20
turbo flange $20-30
Posted on: 2010/3/27 6:29
Its not a garret T3/T4 turbo thats fur sure... its a copy. I wouldnt trust the intercooler either. Impeller blades are most likely ceramic, cooler properties are prolly crap and have massive pressure drop across the center. Turbo timers are a gimic really as a who would drive their car on full boost for ages unless at a track? Normal driving/spirited driving you wont need one.
At the end of the day you get what you pay for. But i wouldnt spend that little on a turbo setup. Last thing iw ould want is part of an impeller go through the cylinder and maybe bend a valve or crack a piston or something.
Not worth the risk in my opinion
Posted on: 2010/3/27 6:31
From newcastle, NSW
doesn't look to bad! especially for a starter kit!
But there is a few parts missing to get it going and off the ground, obviously the manifolds,external wastegate and other odds and ends
I think they sell generic kits, for all cars, minus the manifolds.
Postage from the US is $323 so for about $800 Aus you could have a a half decent sarter kit.
Posted on: 2010/3/27 6:43
Buy it.
Posted on: 2010/3/27 6:45
From Geelong, Vic
but if your only spending that much on a turbo setup then you probably wont have a nice rebuilt/forged engine that your putting it on
the ebay turbos just get shaft play in them real quick. lots of people run cheap ebay coolers, they do the job but obviously if you spend a grand on a cooler its going to be better than a $200 one. but then it wouldnt surprise me if you expensive coolers also used cheaper cores and just stamp/paint a brand on them
would only be the exhaust impeller that would be ceramic but then would a ceramic wheel be cheaper than steel one? coz im doubting that it would be. cant say ive heard of a ceramic front wheeled turbo so you wil only shoot an impeller down the exhaust and kill a cat or muffler if it does let go
Posted on: 2010/3/27 6:48
Ceramic impellers are sure cheaper to make than steel ones. Im not aware of any turbos that use a 2 piece combination as it is just one single shaft through the turbo. All the turbos of the RB series engines where all ceramic bladed turbos. The GTR's were the exception though. they had steel units though dont quote me on it.
HDI which are chinease actually make the better intercoolers on the market even better than those of trust, hks and the like in most cases.
If they arent ball bearing units they are just the normal floating type which are a lot more prone to shaft play and coking of the turbo which may explain why they offer a turbo timer.
Posted on: 2010/3/27 10:06
