Re: help list modifications for a ca18 1200
i would do the injectors and get a good electronic boost controller then go get a retune, i would assume if the turbo is ballbearing it'd be good for 20psi if not find a good secondhand t28bb of an s15
Posted on: 2010/3/27 9:30
the turbo is rated at 400hp as apposed to the t28bb rating at 350hp and it is a ball bearing turbo, tho im worried about the engine internals when under too much boost. ive herd the stock internals are good for 300 hp at the flywheel, is this correct?
Posted on: 2010/3/27 9:42
i think they can handle a bit more than that, there's a guy on here that had 190rwkw pretty sure he had a stock block
Posted on: 2010/3/27 10:00
Id go less on horsepower and more on boost levels. Stock standard CA internals are reliable on 14psi... I know scotty from maddat motorsport has been trialing a 16psi with a high flowed T25 putting out near 170rwkw and thats a daily and hasnt had nething go wrong with it yet
Posted on: 2010/3/27 10:01
From Sydney
start counting your back wallet son..
Posted on: 2010/3/27 11:52
From Canberra
Cheap, Fast, Reliable... Pick 2.
Posted on: 2010/3/27 12:35
YLD.18L
From brisbane
Hi mate
My CA with a T28, intercooler, exhaust, chipped ecu, Bosch 040 pump and 15psi made 163rwkw so, with your current spec list, you should be able able to hit your power goal.
Matty
Posted on: 2010/3/27 13:02
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
In the UK ca18det bottom ends with 8v sohc ca20e style heads are making 200hp atw.
Even older head technology and with forged internals like Piggys ca and the right
manifolds, turbo and tune can make over 250atw no sweat.
There is a ca18det with 411 atw
http://autospeed.com/cms/article.html?&A=1249
Old bmw 2002 engine blocks where used in f1 turbo setups in the early 80s
only after the engines where seasoned with over 100,000klms then a
twin cam head similar in design to the ca18de where used with exotic
fuel for over 1500hp in sprint tune.
ca18det turbo engines give better fuel economy and performance compared
to more cylinders, capacity and price per unit.
They are also lighter than Sr and rotaries by a long margin.
The ultimate turbo Nissan 4 cylinder is still the FJ20ET nothing comes
close and nothing forever will from Nissan problem is weight.
Posted on: 2010/3/27 13:41
From Sydney
mate if the FJ20det was any good go find one from your local wrecker or performance shop, i bet they will say WTF are you on about, FJ20det WERE good but as time goes by they will become rare and old and hard to find, just like the CA in another few years or the next decade,and if anyone can show he hard info on any CA running under 10s and very easy,
and who would be stupid enonugh to throw money on a engine when there are engines already out there with no mods and stock that already pump 200kw and will fit in the datto engine bay...
if you guys are after power find something quicker 13b s6,7,8
if you just feel like giving money away inverst in a old engine
at the end of the day these conversions can cost up to 10 to 20K depending on your taste but you absolutly think you will get more than 5K back... there dirrt cheap on ebay...
but good luck
Posted on: 2010/3/27 21:49
i want to know the most economical way to bring the ca18det to its potential, id be happy with low to mid 12's.
datto13b im not after a 10second car, im after the quickest reasonable ca18det powered 1200 without forking out thousands for forged internals.
Posted on: 2010/3/27 23:18
« 1 (2) 3 4 »
