how does an electric choke work ?
From mandurah
hey i need to know how an electric choke works on a 32/36 weber and what activates the choke ,altinator? and what actualy makes it open ?
any help would be great
Posted on: 2010/3/28 13:45
Re: how does an electric choke work ?
From mandurah
bump anyone ?
Posted on: 2010/3/28 14:15
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth WA AUS
I dont know, maybe a heat sensitive bi-metal thingy!(spring)
Posted on: 2010/3/28 14:17
Datsun 1200 2Dr sedan.
From mandurah
yeah its got a ciol in it that has a terminal on the outside and it is earthed on the side
Posted on: 2010/3/28 14:24
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Perth WA AUS
Same method of operation as the fuel and temp guages on a 1200, normally a variable earth but the choke may be a variable (+).
Posted on: 2010/3/28 14:32
From Perth WA AUS
I dont think that is right about the choke, not sure.
Posted on: 2010/3/28 14:34
From Freo
ignition feed supplies current thru the coil, when it gets hot, opens the choke,
Posted on: 2010/3/28 14:46
A15 PSI Project Motor
'72 CB750k,
From mandurah
ok then so it only comes on when you crank the motor or when its running
and i need some ideas for my gokart
Posted on: 2010/3/28 14:47
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
