SR20VE for my new racecar
From Cape Town, South Africa
I started with a new project build, have a look here: http://datsun1200.com/modules/newbb/v ... hp?topic_id=45104&forum=9
Basically I want to fit a SR20VE to it and a S13 gearbox, but apparently the FWD SR's and the rear wheel drive boxes does not fit together, anybody that can shed some light on this.
The distributor will be removed as I do not want a big ass whole in my fire wall with a crank pick up sensor for the management.
Any other things I should be aware of?
And what is your thoughts regarding this setup.
Posted on: 2010/3/30 11:54
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Re: SR20VE for my new racecar
wtf is a sr20ve
Posted on: 2010/3/30 13:34
From Maraylya nsw
im with you on that one
wtf
Posted on: 2010/3/30 13:35
sr20de out of s13 written of silvia under way
making progress on the 1200 coupe;)
From mandurah
i think its the vvt-i version of the SR20 and im pretty sure they came out in S15s and i wouldnt attempt this convertion as the harnesses are all linked into each other and are the hardest SR to wire up ,unless you go for and after market computer but i highly dout anyone does a computer to suit vvt-i
but good luck
Posted on: 2010/3/30 14:01
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
xtrail gt motor ?
Posted on: 2010/3/30 14:13
1200 ute unfinish'd sr20 $$$
1200 ute stocko
bumble bee drift pig
XR8 tow car / daily
bailz is orsum
This motor is Nissan's answer to Variable Valve Timing.
Nissan Ecology Oriented Variable Valve Lift and Timing (commonly known as VVL) is an automobile variable valve timing technology developed by Nissan. VVL varies the timing, duration, and lift of valves by using hydraulic pressure switch between two different sets of camshaft lobes. It functions similarly to Honda's VTEC system.
The SR20VE is the most common engine with NEO VVL. There have been two main versions of this engine. The first version made 187 hp (139 kW) and 145 lbft (197 Nm) torque. This engine was used by Nissan from 1997 to 2001. It is found in the Nissan Primera, Nissan Bluebird, and the Nissan Wingroad.
Have a look here: http://en.wikipedia.org/wiki/Nissan_VVL_engine
The wiring harness is the least of my issues, will be using the harness of a aftermarket management.
Posted on: 2010/3/30 14:37
www.race-tech.co.za
From South-Africa,Pretoria
Hey racetech,
I want 2 do the same eventually with my bakkie, No the fwd Sr20 sub is diffrent from the Rwd and the Sr20Ve Sub is diffrent as the other two sub's for it has oil channels that feed the cylinderhead for the V-tech. Apparently there is a modification you can make to the Fwd sub to make it fit a rwd gearbox. I would say remove the dizzy and run a Aftermarket fuel system on wasted spark, but as sad as it is, the Sr20Ve has an vtech controller at the back of its cylinder head aswell so you are going 2 have to cut the firewall in anycase. Then to remove the issue with the throttle body pointing to the fire wall as it is an fwd engine ... get a set of ITB's ?
Posted on: 2010/3/30 16:27
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
From Brisbane, Queensland
My vote would be for a SR16VE ...with a turbo on the side Bloody fantastic engine!
I was tossing up between it and the 4G92 MIVEC engine I eventually ended up buying.
..actually I'd go the Mivec engine as it's half the price, has the same power (+-1 or 2kw) but with more torque, bolt on the factory turbo manifolds etc from the 4G93 turbo AAAND you can bolt up a RWD box to it
But then you'd be going Mitsi instead of keeping a Nissan heart in it. Up to you really!
Posted on: 2010/3/31 3:23
Boundaries are only formed by a limited imagination...
lol mitsi engines
Posted on: 2010/3/31 5:30
1200 ute stocko
XR8 tow car / daily
bailz is orsum
spraycanmansam: the sr16ve is a very nice motor, but very scares in RSA and I want to keep it N/A for racing purposes.
Clive: Ok, so the firewall wil have to be cut, then it will be done, but this motor will go in. Will be using my set of 43mm Throttles on the motor.
Still I'm looking for info on the modifications needed to be done to mate this motor to a RWD box. What is the gearbox numbers of the S13 and so on, what boxes does other members use with the sr20 de and det installs.
Posted on: 2010/3/31 10:31
www.race-tech.co.za
