This motor is Nissan's answer to Variable Valve Timing.
Nissan Ecology Oriented Variable Valve Lift and Timing (commonly known as VVL) is an automobile variable valve timing technology developed by Nissan. VVL varies the timing, duration, and lift of valves by using hydraulic pressure switch between two different sets of camshaft lobes. It functions similarly to Honda's VTEC system.
The SR20VE is the most common engine with NEO VVL. There have been two main versions of this engine. The first version made 187 hp (139 kW) and 145 lb·ft (197 N·m) torque. This engine was used by Nissan from 1997 to 2001. It is found in the Nissan Primera, Nissan Bluebird, and the Nissan Wingroad.
Have a look here:
http://en.wikipedia.org/wiki/Nissan_VVL_engineThe wiring harness is the least of my issues, will be using the harness of a aftermarket management.
