stanza strut info please
From the central coast, nsw
hey guys everyone probs already knows the answer to this question but ive got a 1200 ute im doin up, and ive been told when i brought it it had stanza or 180b struts in it. to me it looks like its got some positive camber, how do u fix this? different comtrol arms, ball joints, looking for the cheapest way out guys thanks please give me some clews
Posted on: 2010/4/6 13:40
Re: stanza strut info please
From mandurah
i would go for adjustable camber tops , and i think datsport or someone does them not sure about maddat though
and what control arms ,LCAs ,castor rods are you running ?
Posted on: 2010/4/6 14:06
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
honestly not sure on wat lower control arms they are, there probs 1200 ones hence the reason of the + camber, and the castor rods look fair small.
Posted on: 2010/4/6 14:13
From mandurah
for the stanza struts to work you will need
late 120y or late 1200 ute LCAs /lower control arms
late 120y or late 120y ute caster rods
sunny or stanza ball joints ,steering arms ,outter tir rod ends and tie rods
oh and a few people go for adjustable strut tops as you can then get rid of any extra camber
hope this help
Posted on: 2010/4/6 14:16
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From mandurah
oh and maddat do a complete bottom end kit for 370 and you just need to tell them that your running stanza stuts ,im getting this kit in a week or 2 and its all been sand blasted and powder coated so it looks good too
Posted on: 2010/4/6 14:20
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
cheers mate ill look over mine tomorro n see wat ive got on there
Posted on: 2010/4/6 14:22
stanza ball joints will give you less pos camber where as 1200 late ute ones give you more positive camber.
Best solution i found was s13 camber tops. can be had cheaply 2nd hand(for less then $100 if you really look hard) but new is always best (can be found form $100 if you look really hard).
They dont give you insane amounts of neg camber but mine fully adjusted inwards with 1200 ute balljoints give me just less then 1deg neg camber. with stanza ball joints i didnt have to adjust them to full for 1.5deg neg camber.
Posted on: 2010/4/6 22:24
