Re: building an a14
From perth western australia
yeah no worries mate. another bloke on here is dundee1000 he is a great help he gets all of my parts for me pretty much.
Posted on: 2010/4/9 18:22
1000 coupe aka kb10
WHERE THE HELL IS ROBOCOP... DOES ANYONE KNOW
Re: building an a14
From dominican republic
well the problem is that i live in the dominican republic and is not easy to find all the parts
Posted on: 2010/4/9 18:24
Re: building an a14
yeah mike is able to get a lot of parts through bprojects. they deal with pretty much everything lol
Posted on: 2010/4/10 3:12
1000 coupe aka kb10
Re: building an a14
From Albany, Perth Australia
h89 head double valve springs, mild cam, twin sidies extractors, electric dizzy and all should be fine. Dont need much more then that
Posted on: 2010/4/10 3:23
1200 Smerf Mobile
Re: building an a14
Hi, Have you or a friend got a welder and/or any good at it?
With a weekend and about $50.00 worth of 1 inch ID steam pipe bends you could make a pretty sweet turbo manifold set up for your A14.
Is your turbo fitted with a carbon seal (can it be converted?) if so you could make a very simple draw through turbo setup, I have run a draw through turbo setup on my A15 for 10 years plus (30+psi boost)and found it to be both economical and very reliable.
On the other hand you could go for a blow through setup (if your turbo is not fitted with a carbon seal) however this type of setup is a little more tricky to get setup and get running properly.
A turbo charged A-series is a beautiful thing and make buckets of torque all on standard internals, just don`t rev the piss out of them (6000rpm+)
Somthing to think about anyway.
Cheers,
G O T H E D A T!!
Posted on: 2010/4/10 3:42
Jesus drove a datsun
`67 B10 Turbo white
`69 VB10 red
`71 S30 (240z) orange 432R style
`78 P330 (280c) president matte black
`76 p330 (260c) wagon silver
`96 Toyota Hiace 2.8 diesel LWB
Re: building an a14
hi guys im going on the turbo a14 but i want no carbi on it i want to go EFI im after a complete EFI manifold if anyone can help me
thanks
Posted on: 2010/6/9 22:44
Re: building an a14
Why is double valve springs being suggested - surely stronger single ones would do?
Even my circa '79 A12 will rev to 8000 on bike carbs and extractors using stock springs - not many street-able cam grinds would need rpm capabilities higher than that surely?!
Posted on: 2010/6/9 23:17
« 1 (2)
