Re: B110 Understeer while cornering!!! Arghhh
From Las Vegas USA
Ronald while I too suspect the welded diff is the root cause you have several things going on with the set up. First what condition does it understeer? Corner Entry? Mid Corner Exit? Under Acceleration?? Steady throttle?
First there is the welded Diff, then you're using 60 series fronts (stiff sidewall) in combination with 80 series rears (tall soft side wall). Also you put stiffer springs in the front while leaving the stockers in the rear which will also changing the balance toward understeer. Finally while you put heavier oil in the front dampers if it can't control the stiffer spring the front tires will be oscillating up and down (read not on the ground)
Put the open diff back in, get a matched set of tires, if the rear isn't lowered to match the front correct it and then see what it does.
Tom
Posted on: 2010/4/13 5:08
Subject Poster Date
     B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/12 14:58
       Re: B110 Understeer while cornering!!! Arghhh ANGE 2010/4/12 21:41
       Re: B110 Understeer while cornering!!! Arghhh dattodude 2010/4/12 22:23
         Re: B110 Understeer while cornering!!! Arghhh benny 2010/4/12 23:12
           Re: B110 Understeer while cornering! Dodgeman 2010/4/16 13:30
             Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 14:39
       Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/13 5:08
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/13 13:14
           Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/14 2:26
       Re: B110 Understeer while cornering!!! Arghhh Anonymous 2010/4/14 10:54
         Re: B110 Understeer while cornering!!! Arghhh racinaround 2010/4/14 12:55
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/14 13:31
       Re: B110 Understeer while cornering!!! Arghhh jmac 2010/4/14 21:00
         Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/16 2:59
       Re: B110 Understeer while cornering!!! Arghhh Anonymous 2010/4/16 3:38
       Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 6:25
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 6:34
       Re: B110 Understeer while cornering!!! Arghhh Anonymous 2010/4/16 10:04
       Re: B110 Understeer while cornering!!! Arghhh jmac 2010/4/16 14:58
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/16 15:39
           Re: B110 Understeer while cornering!!! Arghhh estyre 2010/4/16 16:12
             Re: B110 Understeer while cornering!!! Arghhh Rallytwit 2010/4/17 1:33
               Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/17 9:30
         Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/22 15:26
       Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/4/22 15:32
       Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/6/30 7:18
         Re: B110 Understeer while cornering!!! Arghhh benny 2010/6/30 7:22
           Re: B110 Understeer while cornering!!! Arghhh ronald_loulan 2010/6/30 7:33
