Re: help with my a15
often the filter doesn't appear to fill up, that is not necessarily a problem. You can test the fuel pump like this: http://datsun1200.com/modules/mediawi ... e=Fuel_pump_pressure_test
But you probably need to blow the hard line out with compressed air.
Posted on: 2010/4/15 8:54
thanks guys i found the problem, i checked the fuel pump like you said and its fine. the problem is in the tank, i tried to blow out the clog with 90psi of compressed air but nothing so im going to have to drop the tank and clean it. looks like a nice weekend job
also what do you think of this jet set up for a stock a15 with a 32/36 weber?
main jet 140/145
air jet 160/170
idle jet 50/55
e-tube F6/F6
thanks alot guys
Posted on: 2010/4/15 21:34
« 1 (2)
