a question re: directional Simmon's
Hi peoples
Thankyou all for the money saving advice re the gearbox, my mate realised that my simmons on my mitsu might fit so we tried them out, have a look, as last time a picture was all it took for advice :)
Posted on: 2010/4/17 13:07
Re: a question re: directional Simmon's
From Perth WA AUS
Nice, is that a can of MB in the second shot? Haven't seen that beer for ages in Perth.
Posted on: 2010/4/17 13:20
Datsun 1200 2Dr sedan.
From mandurah
wow b45s look good on a 1200 ,i might put my gold spoke simmon copies on !
Posted on: 2010/4/17 13:36
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
It sure is, PM me with a address and I'll send you a can :)
Posted on: 2010/4/17 13:38
From mandurah
levey will need more than one can to keep him goin :)
fedex him a carton haha
Posted on: 2010/4/17 14:23
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
My mates donated me some disc brake fronts, which I'll machine up and get the studs replaced with slightly longer ones
I've just bought a twin cylinder brake master booster of ebay for the conversion.
The test last night shows that the 205/55/15's fit but is this enough clearance of the front strut?
Posted on: 2010/4/17 22:49
205 is unlikely to clear the struts.
Unless the wheel offset makes them stick outside the guards like this:
jpg  temp2.jpg (109.11 KB)
174_4bca348d46e43.jpg 800X600 px
Posted on: 2010/4/17 23:19
they hang out by an inch - does this mean you're not for-seeing much more than spacer and stud length problems?
The disc brake front struts 'seem' to have more clearance than the drum brake struts currently on the car, they did rub the lower front corner of the guard at one point in basic turn test.
Posted on: 2010/4/17 23:29
Luck is what happens when Preparation meets Opportunity.....
I don't know if anyone has successfully fitted 205s to the front of a 1200. On the sedan rear 205s will fit if the perfect offset wheel is used. But on the front there is less room.
I reckon with spacers and guard clearance (perhaps overfender flares) it will work.
Posted on: 2010/4/17 23:59
well I'll let you know how it comes together, and post the pic's :)
Posted on: 2010/4/18 8:02
