« 1 (2)
#11 Re: BOV and alternatives
estyre Posted on: 2010/4/18 11:57
hey i dont get it explain to me what a plumb back is and what the difference is between a AFM amd map sensor ?
#12 Re: BOV and alternatives
dattodude Posted on: 2010/4/18 12:06
I run a HKS ssqv on my CA18det. I ran it to atmosphere for 10 minutes (I felt like a dick with the car making all those noises), before I got onto the lathe and turned up an alloy adapter to plumb it back. I copied the picture of the plumb back adapter from pictures on ebay.
AFM(MAFM) reside in front of the turbo and throttle body. They tell the ECU how much air is entering the engine, so fuel can be tuned to suit.
MAP sensor accepts only a vaccuum signal and it not a critical part of the intake.
MAP sensed engine can run atmo BOV.
AFM/MAFM need to run plumb back BOV so all the air entering the engine is being measured properly.
AFM equipped engines will backfire down exhaust due to over-fueling as air is lost via the blow off valve. The ECU measure the air, and setup fuel for it, but the air was wasted out of the BOV, resulting in an over rich mixture.
#13 Re: BOV and alternatives
levey Posted on: 2010/4/18 12:54
Nice work dude!
#14 Re: BOV and alternatives
Fenix_Longbow Posted on: 2010/4/18 22:13
Thats what i meant! :D Cept in more detail, apologies to those i confused!
#15 Re: BOV and alternatives
bones Posted on: 2010/4/19 6:06
To add: I ran a turbo with blow thru setup into a dellorto downdraught, and I had endless kak cause I didn't have a BOV. Every time you tap off and put foot again, you had a "too rich situation" and a flat spot.
#16 Re: BOV and alternatives
Jordan Posted on: 2010/4/19 7:16
running no bov = nice sounding flutter , work better for performance has the boost from the last gear is there ready to go instantly ,,, if you want the flutter to go away get a air box ;)
running a bov = gay
running a bov that is plub'd back is ok
and remember your bov's should be has close to the intake has you can get it .
#17 Re: BOV and alternatives
bones Posted on: 2010/4/19 8:12
Yeah, the "flutter" is the sound of the compressor wheel slowing down (against a pressure caused by the closed throttle body plate) when u tap off. 1. It puts huge strain on your turbo shaft/compressor wheel & vanes 2. It sounds cool but stuffs your turbo up eventually. 3. There is a less than optimum response from your turbo now as it has too spool up again from low speed each time you tap off and re-accelerate
If you want instant boost response put an anti-lag system in the exhaust system ala most WRC cars (and have the cops on yer a$$ as a bonus). Another bonus is you get to replace yer exhaust system rather often
#18 Re: BOV and alternatives
levey Posted on: 2010/4/19 8:33
Makes some nice flames though!
#19 Re: BOV and alternatives
bones Posted on: 2010/4/19 8:41
yeah Levey the flames are fun, so is a back fire (or ten) that sends pedestrians diving for cover, (evil laughter)
#20 Re: BOV and alternatives
levey Posted on: 2010/4/19 10:05
Its lots of fun in peak hour traffic but you get more horn beeps and shaking fists than flames ;)
« 1 (2)
